Webcast-Catalyst9k
ASR card crash
Hi, I need your help, I have an ASR 9600, yestarday the card 0 reloaded and today the card 1, but I don't see anything weird on the logs, can you help me?
LC/0/0/CPU0:May 26 15:07:25.063 : bfd_agent[123]: %L2-BFD-6-SESSION_STATE_DOWN : BFD session to neighbor 10.248.0.254 on interface Bundle-Ether1.3300 has gone down. Reason: Nbor signalled down
RP/0/RSP0/CPU0:May 26 15:07:25.066 : ospf[1011]: %ROUTING-OSPF-5-ADJCHG : Process 100, Nbr 10.248.10.7 on Bundle-Ether1.3300 in area 0 from FULL to DOWN, Neighbor Down: BFD session down,vrf default vrfid 0x60000000
LC/0/0/CPU0:May 26 15:07:28.848 : bfd_agent[123]: %L2-BFD-6-SESSION_STATE_DOWN : BFD session to neighbor 10.248.0.250 on interface Bundle-Ether1.3301 has gone down. Reason: Nbor signalled down
RP/0/RSP0/CPU0:May 26 15:07:28.851 : ospf[1011]: %ROUTING-OSPF-5-ADJCHG : Process 100, Nbr 10.248.10.5 on Bundle-Ether1.3301 in area 0 from FULL to DOWN, Neighbor Down: BFD session down,vrf default vrfid 0x60000000
RP/0/RSP0/CPU0:May 26 15:08:04.485 : bgp[1047]: %ROUTING-BGP-5-ADJCHANGE : neighbor 190.90.20.17 Down - Peer closing down the session (VRF: INTERNET)
RP/0/RSP0/CPU0:May 26 15:08:12.543 : mpls_ldp[1042]: %ROUTING-LDP-5-GR : GR session 10.248.10.3:0 (instance 1) disconnected
RP/0/RSP0/CPU0:May 26 15:08:12.543 : mpls_ldp[1042]: %ROUTING-LDP-5-NBR_CHANGE : Neighbor 10.248.10.3:0, DOWN (Discovery Hello Hold Timer expired)
RP/0/RSP0/CPU0:May 26 15:08:13.170 : mpls_ldp[1042]: %ROUTING-LDP-5-GR : GR session 10.248.10.7:0 (instance 2) disconnected
RP/0/RSP0/CPU0:May 26 15:08:13.171 : mpls_ldp[1042]: %ROUTING-LDP-5-NBR_CHANGE : Neighbor 10.248.10.7:0, DOWN (Discovery Hello Hold Timer expired)
RP/0/RSP0/CPU0:May 26 15:08:13.388 : mpls_ldp[1042]: %ROUTING-LDP-5-GR : GR session 10.248.10.5:0 (instance 7) disconnected
RP/0/RSP0/CPU0:May 26 15:08:13.388 : mpls_ldp[1042]: %ROUTING-LDP-5-NBR_CHANGE : Neighbor 10.248.10.5:0, DOWN (Discovery Hello Hold Timer expired)
RP/0/RSP0/CPU0:May 26 15:08:20.559 : bgp[1047]: %ROUTING-BGP-5-ADJCHANGE : neighbor 2800:310:10:6::19 Down - BGP Notification sent, hold time expired (VRF: INTERNET)
RP/0/RSP0/CPU0:May 26 15:08:36.703 : bgp[1047]: %ROUTING-BGP-5-ADJCHANGE : neighbor 190.90.20.17 Up (VRF: INTERNET)
RP/0/RSP0/CPU0:May 26 15:09:23.815 : pfm_node_rp[326]: %PLATFORM-DIAGS-3-PUNT_FABRIC_DATA_PATH_FAILED : Set|online_diag_rsp[237685]|System Punt/Fabric/data Path Test(0x2000004)|failure threshold is 3, (slot, NP) failed: (3, 1)
RP/0/RSP0/CPU0:May 26 15:09:32.927 : bgp[1047]: %ROUTING-BGP-5-ADJCHANGE : neighbor 10.252.244.15 Down - BGP Notification sent, hold time expired (VRF: INTERNET)
LC/0/1/CPU0:May 26 15:09:37.174 : pfm_node_lc[267]: %PLATFORM-DIAGS-0-LC_NP_LOOPBACK_FAILED : Set|online_diag_lc[155731]|Line card NPU loopback Test(0x2000006)|
LC/0/1/CPU0:May 26 15:09:37.287 : pfm_node_lc[267]: prm_fast_reset_subset fast reset api succeeded for chan 1
LC/0/1/CPU0:May 26 15:09:37.287 : pfm_node_lc[267]: NP loopback recovery action: Succeded (NP bitmask:0x2)
RP/0/RSP1/CPU0:May 26 15:09:42.187 : pfm_node_rp[326]: %PLATFORM-DIAGS-3-PUNT_FABRIC_DATA_PATH_FAILED : Set|online_diag_rsp[233590]|System Punt/Fabric/data Path Test(0x2000004)|failure threshold is 3, (slot, NP) failed: (3, 1)
RP/0/RSP0/CPU0:May 26 15:09:43.342 : bgp[1047]: %ROUTING-BGP-5-ADJCHANGE : neighbor 10.248.10.3 Down - BGP Notification sent, hold time expired (VRF: default)
LC/0/1/CPU0:May 26 15:09:55.722 : prm_server[278]: %PLATFORM-NP-0-INIT_ERR : *** Error 0xA0003F03 : prm_np_fast_reset : Channel 1 Config Start Fast Reset failed, line card will be reloaded
LC/0/1/CPU0:May 26 15:09:55.722 : prm_server[278]: Line card needs to be reloaded, a reboot is being requested
RP/0/RSP0/CPU0:May 26 15:09:55.777 : shelfmgr[361]: %PLATFORM-SHELFMGR-3-NODE_CPU_RESET : Node 0/1/CPU0 CPU reset detected.
RP/0/RSP0/CPU0:May 26 15:09:55.778 : shelfmgr[361]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/1/CPU0 A9K-2T20GE-B state:BRINGDOWN
RP/0/RSP0/CPU0:May 26 15:09:55.863 : invmgr[238]: %PLATFORM-INV-6-NODE_STATE_CHANGE : Node: 0/1/CPU0, state: BRINGDOWN
RP/0/RSP0/CPU0:May 26 15:09:55.990 : BM-DISTRIB[1148]: %L2-BM-6-ACTIVE : GigabitEthernet0/1/0/7 is no longer Active as part of Bundle-Ether5 (Link is being removed from the bundle)
RP/0/RSP0/CPU0:May 26 15:09:55.997 : BM-DISTRIB[1148]: %L2-BM-6-ACTIVE : UNKNOWN intf 0x06000380 is no longer Active as part of Bundle-Ether3 (Link is being removed from the bundle)
RP/0/RSP0/CPU0:May 26 15:09:56.027 : BM-DISTRIB[1148]: %L2-BM-6-ACTIVE : UNKNOWN intf 0x06000340 is no longer Active as part of Bundle-Ether2 (Link is being removed from the bundle)
RP/0/RSP0/CPU0:May 26 15:09:56.034 : BM-DISTRIB[1148]: %L2-BM-6-ACTIVE : UNKNOWN intf 0x06000240 is no longer Active as part of Bundle-Ether1 (Link is being removed from the bundle)
RP/0/RSP0/CPU0:May 26 15:09:56.056 : BM-DISTRIB[1148]: %L2-BM-6-ACTIVE : UNKNOWN intf 0x06000100 is no longer Active as part of Bundle-Ether4 (Link is being removed from the bundle)
RP/0/RSP0/CPU0:May 26 15:09:57.061 : ospf[1011]: %ROUTING-OSPF-5-ADJCHG : Process 100, Nbr 10.248.10.7 on Bundle-Ether1.3300 in area 0 from LOADING to FULL, Loading Done,vrf default vrfid 0x60000000
RP/0/RSP0/CPU0:May 26 15:09:57.698 : bgp[1047]: %ROUTING-BGP-5-ADJCHANGE : neighbor 10.248.10.7 Down - BGP Notification sent, hold time expired (VRF: default)
RP/0/RSP0/CPU0:May 26 15:09:58.606 : ospf[1011]: %ROUTING-OSPF-5-ADJCHG : Process 100, Nbr 10.248.10.5 on Bundle-Ether1.3301 in area 0 from LOADING to FULL, Loading Done,vrf default vrfid 0x60000000
RP/0/RSP0/CPU0:May 26 15:10:00.080 : mpls_ldp[1042]: %ROUTING-LDP-5-NBR_CHANGE : Neighbor 10.248.10.5:0, UP
RP/0/RSP0/CPU0:May 26 15:10:00.080 : mpls_ldp[1042]: %ROUTING-LDP-5-GR : GR session 10.248.10.5:0 (instance 8) reconnected
RP/0/RSP0/CPU0:May 26 15:10:00.794 : mpls_ldp[1042]: %ROUTING-LDP-5-NBR_CHANGE : Neighbor 10.248.10.7:0, UP
RP/0/RSP0/CPU0:May 26 15:10:00.794 : mpls_ldp[1042]: %ROUTING-LDP-5-GR : GR session 10.248.10.7:0 (instance 3) reconnected
RP/0/RSP0/CPU0:May 26 15:10:02.178 : shelfmgr[361]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/1/CPU0 A9K-2T20GE-B state:ROMMON
RP/0/RSP0/CPU0:May 26 15:10:02.592 : mpls_ldp[1042]: %ROUTING-LDP-5-GR : GR session 10.248.10.5:0 (instance 8) disconnected
RP/0/RSP0/CPU0:May 26 15:10:02.595 : mpls_ldp[1042]: %ROUTING-LDP-5-NBR_CHANGE : Neighbor 10.248.10.5:0, DOWN (AToM requested targeted session to existing non-AToM peer)
RP/0/RSP0/CPU0:May 26 15:10:07.969 : mpls_ldp[1042]: %ROUTING-LDP-5-NBR_CHANGE : Neighbor 10.248.10.5:0, UP
RP/0/RSP0/CPU0:May 26 15:10:07.970 : mpls_ldp[1042]: %ROUTING-LDP-5-GR : GR session 10.248.10.5:0 (instance 9) reconnected
RP/0/RSP0/CPU0:May 26 15:10:10.703 : bgp[1047]: %ROUTING-BGP-5-ADJCHANGE : neighbor 2800:310:10:6::19 Up (VRF: INTERNET)
RP/0/RSP0/CPU0:May 26 15:10:10.959 : bgp[1047]: %ROUTING-BGP-5-ADJCHANGE : neighbor 10.252.244.15 Up (VRF: INTERNET)
RP/0/RSP0/CPU0:May 26 15:10:11.532 : mpls_ldp[1042]: %ROUTING-LDP-5-NBR_CHANGE : Neighbor 10.248.10.3:0, UP
RP/0/RSP0/CPU0:May 26 15:10:11.532 : mpls_ldp[1042]: %ROUTING-LDP-5-GR : GR session 10.248.10.3:0 (instance 2) reconnected
RP/0/RSP0/CPU0:May 26 15:10:17.336 : bgp[1047]: %ROUTING-BGP-5-ADJCHANGE : neighbor 10.248.10.3 Up (VRF: default)
LC/0/0/CPU0:May 26 15:10:19.502 : bfd_agent[123]: %L2-BFD-6-SESSION_STATE_UP : BFD session to neighbor 10.248.0.250 on interface Bundle-Ether1.3301 is up
LC/0/0/CPU0:May 26 15:10:19.853 : bfd_agent[123]: %L2-BFD-6-SESSION_STATE_UP : BFD session to neighbor 10.248.0.254 on interface Bundle-Ether1.3300 is up
RP/0/RSP0/CPU0:May 26 15:10:23.517 : shelfmgr[361]: %PLATFORM-SHELFMGR_HAL-6-BOOT_REQ_RECEIVED : Boot Request from 0/1/CPU0, RomMon Version: 1.5
RP/0/RSP0/CPU0:May 26 15:10:23.531 : shelfmgr[361]: %PLATFORM-MBIMGR-7-IMAGE_VALIDATED : Remote location 0/1/CPU0: : MBI tftp:/disk0/asr9k-os-mbi-4.1.0/lc/mbiasr9k-lc.vm validated
RP/0/RSP0/CPU0:May 26 15:10:23.537 : shelfmgr[361]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/1/CPU0 A9K-2T20GE-B state:MBI-BOOTING
RP/0/RSP0/CPU0:May 26 15:10:23.834 : pfm_node_rp[326]: %PLATFORM-DIAGS-3-PUNT_FABRIC_DATA_PATH_FAILED : Clear|online_diag_rsp[237685]|System Punt/Fabric/data Path Test(0x2000004)|failure threshold is 3, (slot, NP) failed: (3, 1)
RP/0/RSP0/CPU0:May 26 15:10:28.277 : bgp[1047]: %ROUTING-BGP-5-ADJCHANGE : neighbor 10.248.10.5 Down - BGP Notification sent, hold time expired (VRF: default)
RP/0/RSP0/CPU0:May 26 15:10:29.070 : bgp[1047]: %ROUTING-BGP-5-ADJCHANGE : neighbor 10.248.10.7 Up (VRF: default)
RP/0/RSP0/CPU0:May 26 15:10:31.848 : tcp[394]: %IP-TCP-3-BADAUTH : Invalid MD5 digest from 2800:310:10:6::19:179 to 2800:310:10:6::1a:62070
RP/0/RSP1/CPU0:May 26 15:10:42.200 : pfm_node_rp[326]: %PLATFORM-DIAGS-3-PUNT_FABRIC_DATA_PATH_FAILED : Clear|online_diag_rsp[233590]|System Punt/Fabric/data Path Test(0x2000004)|failure threshold is 3, (slot, NP) failed: (3, 1)
RP/0/RSP0/CPU0:May 26 15:10:59.671 : bgp[1047]: %ROUTING-BGP-5-ADJCHANGE : neighbor 10.248.10.5 Up (VRF: default)
RP/0/RSP0/CPU0:May 26 15:11:30.158 : shelfmgr[361]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/1/CPU0 A9K-2T20GE-B state:MBI-RUNNING
RP/0/RSP0/CPU0:May 26 15:11:31.848 : tcp[394]: %IP-TCP-3-BADAUTH : Invalid MD5 digest from 2800:310:10:6::19:179 to 2800:310:10:6::1a:62070
LC/0/1/CPU0:17: init[65540]: %OS-INIT-7-MBI_STARTED : total time 10.454 seconds
LC/0/1/CPU0:May 26 15:11:33.448 : insthelper[61]: %INSTALL-INSTHELPER-7-PKG_DOWNLOAD : MBI running; starting software download
LC/0/1/CPU0:May 26 15:11:49.979 : sysmgr[89]: %OS-SYSMGR-5-NOTICE : Card is COLD started
LC/0/1/CPU0:May 26 15:11:50.285 : init[65540]: %OS-INIT-7-INSTALL_READY : total time 31.309 seconds
LC/0/1/CPU0:May 26 15:11:51.753 : sysmgr[320]: %OS-SYSMGR-6-INFO : Backup system manager is ready
LC/0/1/CPU0:May 26 15:11:52.810 : syslog_dev[87]: dumper_config[148]:
LC/0/1/CPU0:May 26 15:11:52.837 : syslog_dev[87]: dumper_config[148]:  The node id is 2097
LC/0/1/CPU0:May 26 15:12:12.420 : prm_server[278]: %PLATFORM-QOSHAL-6-QOS_MODE_CHANGE : Line-card QoS mode set to child-shaping-enabled.
LC/0/1/CPU0:May 26 15:12:12.421 : prm_server[278]: %PLATFORM-QOSHAL-6-QOS_MODE_CHANGE : Line-card QoS mode set to lowburst-disabled.
LC/0/1/CPU0:May 26 15:12:21.223 : sysmgr[89]: %OS-SYSMGR-7-DEBUG : sysmgr_admin_plane_check:SYSMGR_PLANE_ADMIN Notification sent.
LC/0/1/CPU0:May 26 15:12:27.433 : fia_lc[163]: mace_client_init: Client already connected
RP/0/RSP0/CPU0:May 26 15:12:31.851 : tcp[394]: %IP-TCP-3-BADAUTH : Invalid MD5 digest from 2800:310:10:6::19:179 to 2800:310:10:6::1a:62070
LC/0/1/CPU0:May 26 15:12:41.924 : fib_mgr[164]: %PLATFORM-PLAT_FIB-4-GRE_UNSUPPORTED : IPv6 not supported on interface tunnel-ip8. Please remove the config.
RP/0/RSP0/CPU0:May 26 15:12:55.247 : shelfmgr[361]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/1/CPU0 A9K-2T20GE-B state:IOS XR RUN
RP/0/RSP0/CPU0:May 26 15:12:55.254 : invmgr[238]: %PLATFORM-INV-6-NODE_STATE_CHANGE : Node: 0/1/CPU0, state: IOS XR RUN
LC/0/1/CPU0:May 26 15:13:01.074 : ETHER_CTRL[158]: %PLATFORM-ETHER_CTRL-4-XCVR_WARNING : SFP for port 7 is disabled - Non-compliant
LC/0/1/CPU0:May 26 15:13:01.089 : pfm_node_lc[267]: %PLATFORM-SFP-2-DEV_SFP_COMPLIANCE_ERROR : Set|ether_ctrl_lc_ge[176247]|SFP(0x1028007)|SFP Module for port 07 is not Cisco compliant
LC/0/1/CPU0:May 26 15:13:13.492 : ifmgr[186]: %PKT_INFRA-LINK-5-CHANGED : Interface TenGigE0/1/0/1, changed state to Administratively Down
LC/0/1/CPU0:May 26 15:13:13.498 : ifmgr[186]: %PKT_INFRA-LINK-3-UPDOWN : Interface TenGigE0/1/0/0, changed state to Down
LC/0/1/CPU0:May 26 15:13:13.499 : ifmgr[186]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface TenGigE0/1/0/0, changed state to Down
LC/0/1/CPU0:May 26 15:13:13.503 : cfgmgr-lc[133]: %MGBL-CONFIG-6-OIR_RESTORE : Configuration for node '0/1/0' has been restored.
LC/0/1/CPU0:May 26 15:13:14.348 : ifmgr[186]: %PKT_INFRA-LINK-3-UPDOWN : Interface TenGigE0/1/0/0, changed state to Up
LC/0/1/CPU0:May 26 15:13:14.351 : ifmgr[186]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface TenGigE0/1/0/0, changed state to Up
RP/0/RSP0/CPU0:May 26 15:13:18.174 : BM-DISTRIB[1148]: %L2-BM-6-ACTIVE : TenGigE0/1/0/0 is Active as part of Bundle-Ether4
LC/0/1/CPU0:May 26 15:13:38.571 : ifmgr[186]: %PKT_INFRA-LINK-5-CHANGED : Interface GigabitEthernet0/1/0/19, changed state to Administratively Down
LC/0/1/CPU0:May 26 15:13:38.571 : ifmgr[186]: %PKT_INFRA-LINK-5-CHANGED : Interface GigabitEthernet0/1/0/18, changed state to Administratively Down
LC/0/1/CPU0:May 26 15:13:38.572 : ifmgr[186]: %PKT_INFRA-LINK-5-CHANGED : Interface GigabitEthernet0/1/0/17, changed state to Administratively Down
LC/0/1/CPU0:May 26 15:13:38.572 : ifmgr[186]: %PKT_INFRA-LINK-5-CHANGED : Interface GigabitEthernet0/1/0/16, changed state to Administratively Down
LC/0/1/CPU0:May 26 15:13:38.573 : ifmgr[186]: %PKT_INFRA-LINK-5-CHANGED : Interface GigabitEthernet0/1/0/15, changed state to Administratively Down
LC/0/1/CPU0:May 26 15:13:38.573 : ifmgr[186]: %PKT_INFRA-LINK-5-CHANGED : Interface GigabitEthernet0/1/0/14, changed state to Administratively Down
LC/0/1/CPU0:May 26 15:13:38.573 : ifmgr[186]: %PKT_INFRA-LINK-5-CHANGED : Interface GigabitEthernet0/1/0/13, changed state to Administratively Down
LC/0/1/CPU0:May 26 15:13:38.574 : ifmgr[186]: %PKT_INFRA-LINK-5-CHANGED : Interface GigabitEthernet0/1/0/12, changed state to Administratively Down
LC/0/1/CPU0:May 26 15:13:38.574 : ifmgr[186]: %PKT_INFRA-LINK-5-CHANGED : Interface GigabitEthernet0/1/0/11, changed state to Administratively Down
LC/0/1/CPU0:May 26 15:13:38.574 : ifmgr[186]: %PKT_INFRA-LINK-5-CHANGED : Interface GigabitEthernet0/1/0/10, changed state to Administratively Down
LC/0/1/CPU0:May 26 15:13:38.575 : ifmgr[186]: %PKT_INFRA-LINK-3-UPDOWN : Interface GigabitEthernet0/1/0/9, changed state to Down
LC/0/1/CPU0:May 26 15:13:38.575 : ifmgr[186]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface GigabitEthernet0/1/0/9, changed state to Down
LC/0/1/CPU0:May 26 15:13:38.575 : ifmgr[186]: %PKT_INFRA-LINK-5-CHANGED : Interface GigabitEthernet0/1/0/8, changed state to Administratively Down
LC/0/1/CPU0:May 26 15:13:38.576 : ifmgr[186]: %PKT_INFRA-LINK-3-UPDOWN : Interface GigabitEthernet0/1/0/7, changed state to Down
LC/0/1/CPU0:May 26 15:13:38.576 : ifmgr[186]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface GigabitEthernet0/1/0/7, changed state to Down
LC/0/1/CPU0:May 26 15:13:38.576 : ifmgr[186]: %PKT_INFRA-LINK-3-UPDOWN : Interface GigabitEthernet0/1/0/6, changed state to Down
LC/0/1/CPU0:May 26 15:13:38.576 : ifmgr[186]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface GigabitEthernet0/1/0/6, changed state to Down
LC/0/1/CPU0:May 26 15:13:38.576 : ifmgr[186]: %PKT_INFRA-LINK-3-UPDOWN : Interface GigabitEthernet0/1/0/5, changed state to Down
LC/0/1/CPU0:May 26 15:13:38.576 : ifmgr[186]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface GigabitEthernet0/1/0/5, changed state to Down
LC/0/1/CPU0:May 26 15:13:38.577 : ifmgr[186]: %PKT_INFRA-LINK-3-UPDOWN : Interface GigabitEthernet0/1/0/4, changed state to Down
LC/0/1/CPU0:May 26 15:13:38.577 : ifmgr[186]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface GigabitEthernet0/1/0/4, changed state to Down
LC/0/1/CPU0:May 26 15:13:38.578 : ifmgr[186]: %PKT_INFRA-LINK-5-CHANGED : Interface GigabitEthernet0/1/0/3, changed state to Administratively Down
LC/0/1/CPU0:May 26 15:13:38.578 : ifmgr[186]: %PKT_INFRA-LINK-5-CHANGED : Interface GigabitEthernet0/1/0/2, changed state to Administratively Down
LC/0/1/CPU0:May 26 15:13:38.578 : ifmgr[186]: %PKT_INFRA-LINK-3-UPDOWN : Interface GigabitEthernet0/1/0/1, changed state to Down
LC/0/1/CPU0:May 26 15:13:38.579 : ifmgr[186]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface GigabitEthernet0/1/0/1, changed state to Down
LC/0/1/CPU0:May 26 15:13:38.579 : ifmgr[186]: %PKT_INFRA-LINK-5-CHANGED : Interface GigabitEthernet0/1/0/0, changed state to Administratively Down
LC/0/1/CPU0:May 26 15:13:38.610 : cfgmgr-lc[133]: %MGBL-CONFIG-6-OIR_RESTORE : Configuration for node '0/1/0' has been restored.
LC/0/1/CPU0:May 26 15:13:38.810 : ETHER_CTRL[158]: %L2-ETHERNET-6-MTU_NEAR_HW_LIMIT : The configured MTU of 9216 on GigabitEthernet0_1_0_6 is close to the H/W limit, and hence large 802.1Q or QinQ frames may be dropped as oversized frames
LC/0/1/CPU0:May 26 15:13:39.497 : ifmgr[186]: %PKT_INFRA-LINK-3-UPDOWN : Interface GigabitEthernet0/1/0/1, changed state to Up
LC/0/1/CPU0:May 26 15:13:39.502 : ifmgr[186]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface GigabitEthernet0/1/0/1, changed state to Up
LC/0/1/CPU0:May 26 15:13:39.508 : ifmgr[186]: %PKT_INFRA-LINK-3-UPDOWN : Interface GigabitEthernet0/1/0/4, changed state to Up
RP/0/RSP0/CPU0:May 26 15:13:39.522 : BM-DISTRIB[1148]: %L2-BM-6-ACTIVE : GigabitEthernet0/1/0/1 is Active as part of Bundle-Ether1
LC/0/1/CPU0:May 26 15:13:39.515 : ifmgr[186]: %PKT_INFRA-LINK-3-UPDOWN : Interface GigabitEthernet0/1/0/5, changed state to Up
LC/0/1/CPU0:May 26 15:13:39.524 : ifmgr[186]: %PKT_INFRA-LINK-3-UPDOWN : Interface GigabitEthernet0/1/0/6, changed state to Up
LC/0/1/CPU0:May 26 15:13:39.528 : ifmgr[186]: %PKT_INFRA-LINK-3-UPDOWN : Interface GigabitEthernet0/1/0/7, changed state to Up
LC/0/1/CPU0:May 26 15:13:41.618 : ifmgr[186]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface GigabitEthernet0/1/0/4, changed state to Up
LC/0/1/CPU0:May 26 15:13:41.634 : ifmgr[186]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface GigabitEthernet0/1/0/5, changed state to Up
LC/0/1/CPU0:May 26 15:13:41.642 : ifmgr[186]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface GigabitEthernet0/1/0/6, changed state to Up
RP/0/RSP0/CPU0:May 26 15:13:41.646 : BM-DISTRIB[1148]: %L2-BM-6-ACTIVE : GigabitEthernet0/1/0/5 is Active as part of Bundle-Ether2
LC/0/1/CPU0:May 26 15:13:41.647 : ifmgr[186]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface GigabitEthernet0/1/0/7, changed state to Up
RP/0/RSP0/CPU0:May 26 15:13:41.659 : BM-DISTRIB[1148]: %L2-BM-6-ACTIVE : GigabitEthernet0/1/0/6 is Active as part of Bundle-Ether3
RP/0/RSP0/CPU0:May 26 15:13:43.674 : BM-DISTRIB[1148]: %L2-BM-6-ACTIVE : GigabitEthernet0/1/0/7 is Active as part of Bundle-Ether5
Everyone's tags (1)
1 REPLY
Anonymous
N/A
Hi, Juan Barco
Please check the TE card physical status.
Thanks.
368
