ASR1001, Portchannel, Vlans, vrf and ospfv2
I wants to bundle 2 of the ASR1001 interfaces to a Portchannel using lacp.
In this portchannel we wants to use vlans and vrf and ospfv2.
So the ASR 1001 should behave like a switch with a portchannel with several vlans on it.
So the resulting config will look like this on the asr1001
ip vrf a
rd 1:1
ip vrf b
rd 2:1
interface GigabitEthernet1/0/0
no ip address
negotiation auto
channel-group 1
interface GigabitEthernet1/0/1
no ip address
negotiation auto
channel-group 1
interface Port-channel1
interface Port-channel1.10
ip vrf forwarding a
ip address 10.0.10.1 255.255.255.0
encapsulation dot1Q 10
ip ospf 1 area 10
ip ospf multi-area 11
interface Port-channel1.20
ip vrf forwarding a
ip address 10.0.20.1 255.255.255.0
encapsulation dot1Q 20
ip ospf 1 area 20
ip ospf multi-area 21
router ospf 1 vrf a
network 10.0.10.0 0.0.0.255 area 0
router ospf 1 vrf b
network 10.0.20.0 0.0.0.255 area 0
I searched the web, but i did not find any examples, which confirms, this will work this way.
I have only found this document, which goes into this direction:
http://www.cisco.com/en/US/docs/ios-xml/ios/lanswitch/configuration/xe-3s/asr1000/lnsw-flow-portchannel-load.html
or this one, not sure for which platform this was written:
http://www.cisco.com/en/US/docs/ios/lanswitch/configuration/guide/lsw_cfg_gecvlan_ps9587_TSD_Products_Configuration_Guide_Chapter.html
I can not test it anywhere at the moment, and i want to decide, if this router is usable for this scenario or not.
Everyone's tags (3)
1 ACCEPTED SOLUTION
I confirm that the ASR1K device can be used to implement the above configuration.
***********Plz do rate this post if you found it helpful*************************
Thanks & Regards,
Vignesh R P
Thanks & Regards,
Vignesh R P
Meanwhile i have found a ASR1k for testing. It works indeed. Some syntaxerrors in the config, but technicaly it works.
2709
