Community Member
ASR1004 RSA Key Generation Failure
I am currently trying to configure SSH access to an ASR1004 Router.  When running the following commands to generate my keys:
Router(config)#crypto key generate rsa
I am getting the following output:
How many bits in the modulus [512]: 1024
% Generating 1024 bit RSA keys, keys will be non-exportable...
% Error in generating keys:no available resources
I get this error when trying lower bits (512) as well..
Anyone seen this before and/or know of any solutions?
Thanks!
Community Member
Here is my IOS version:
Router#show version
Cisco IOS Software, IOS-XE Software (PPC_LINUX_IOSD-ADVIPSERVICESK9-M), Version 12.2(33)XNB1, RELEASE SOFTWARE (fc1)
Highlighted
Community Member
Hi Kristopher,
You are hitting a bug CSCsu68592, you should upgrade version to avoid it.
Here are the details:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsu68592
Symptom:
When generating the RSA keypair on the ASR router the following error message is returned.
Conditions:
attempting to create new RSA keypair
the following command is entered
crypto key generate rsa general-keys label key1 modulus 1024 exportable
The device returns the following
The name for the keys will be: key1
% The key modulus size is 1024 bits
% Generating 1024 bit RSA keys, keys will be exportable...
This behavior is the same regardless of whether or not the keys are exportable and / or labeled
Workaround:
no known workaround at this time.
246
