ASR1006 cannot upgrade rommon
yangyu2
ASR1006# upgrade rom-monitor filename bootflash:asr1000-rommon.153-3r.S1.pkg all
Upgrade rom-monitor on Route-Processor 0
Target copying rom-monitor image file
rsync: link_stat "rommon/mcp/RP/RP2/latest.bin" (in rommon_upgrade_pub) failed: No such file or directory (2)
rsync error: some files could not be transferred (code 23) at /auto/mcpbuilds13/release/03.07.03.S/BLD-03.07.03.S/contrib/rsync/main.c(1392) [receiver=2.6.9]
ASR1006#show platform
Chassis type: ASR1006
Slot      Type                State                 Insert time (ago)
0         ASR1000-SIP10       ok                    00:11:22
0/2      SPA-5X1GE-V2        ok                    00:10:14
2         ASR1000-SIP10       ok                    00:11:22
R0        ASR1000-RP2         ok, active            00:11:22
P0        ASR1006-PWR-AC      ok                    00:11:05
P1        ASR1006-PWR-AC      ok                    00:11:04
Slot      CPLD Version        Firmware Version
0         09111601            12.2(33r)XNC
2         09111601            12.2(33r)XNC
R0        10021901            15.3(1r)S
ASR1006 with RP2, running asr1000rp2-adventerprisek9.03.07.03.S.152-4.S3.bin
7 Replies 7
Leo Laohoo
Means the bootstrap file is not found in the place you've specified, i.  e.  the bootflash.
Can you please post the output to the command "dir"?
ASR1006#dir
Directory of bootflash:/
   11  drwx       16384  Nov 25 2010 03:15:16 +00:00  lost+found
193537  drwx        4096   Nov 5 2012 02:14:00 +00:00  vman_fdb
129025  drwx        4096  Nov 25 2010 03:18:18 +00:00  .installer
48385  drwx        4096  Aug 27 2013 23:39:52 +00:00  .prst_sync
64513  drwx        4096  Nov 25 2010 03:47:43 +00:00  .rollback_timer
   14  -rw-     2361648  Mar 14 2013 15:28:21 +00:00  asr1000-rommon.153-1r.S.pkg
48386  -rw-   598912444  Aug 27 2013 01:48:16 +00:00  asr1000rp2-adventerprisek9.03.09.00.S.153-2.S.bin
   12  -rw-   569597380   Oct 9 2013 13:23:38 +00:00  asr1000rp2-adventerprisek9.03.10.00.S.153-3.S-ext.bin
   13  -rw-    15261696   Oct 9 2013 13:25:35 +00:00  asa824-11-k8.bin
209667  -rw-        7745  Aug 23 2013 23:22:13 +00:00  packages.conf
   15  -rw-      555312  Oct 25 2013 22:14:35 +00:00  asr1000-rommon.153-3r.S1.pkg
   16  -rw-   484677032  Oct 25 2013 22:36:09 +00:00  asr1000rp2-adventerprisek9.03.07.03.S.152-4.S3.bin
The error pops up when I try to upgrade rommon
I know what is going on ...
Your file is "corrupt" or download was not completed.  Look at the file size.  It doesn't add up.
Do this command "verify /md5 bootflash:asr1000-rommon.153-3r.S1.pkg 7d7b3342b4922b7216ceea8bf112caf4" and I can assure you this will kick up an error message.
"7d7b3342b4922b7216ceea8bf112caf4" is the MD5 hash value taken from the Cisco website.  Besides, look at the file size listed in the Cisco website.  The file is suppose to be "2.42 MB".
ASR1006#verify /md5 bootflash:
bootflash:asr1000-rommon.153-3r.S1.pkg c818ccd5af831f844646a74ffe33d1d8
........................................................................................................................................Done!
Verified (bootflash:asr1000-rommon.153-3r.S1.pkg) = c818ccd5af831f844646a74ffe33d1d8
MD5 is actually correct.
ASR1000 Series ROM Monitor upgrade package for Gigabit Ethernet Linecard
ASR1000 Series ROM Monitor upgrade package for m8500 and x86
asr1000-rommon.152-4r.S1.fc1.pkg
Confused. What is the rommon upgrade for?
Resolved Caveats in ROMmon Release 15.3(3r)S1
The following issue has been resolved in Release 15.3(3r)S1:
CSCui25176
Modified the CPLD's HKP PLL configuration register value in the Cisco ASR 1000 Ethernet Line Card to reflect IBM's recommended value for the correct HKP PLL configuration.
Check out the bug.  If you have the line card affected, then upgrade to 15.3(3r)S1.  Otherwise, don't worry about it.
The second software is an older ROMmon.
Try transfer the file in ftp binary mode rather than ascii mode
User404
I have a similar problem.
I have some ASR1006 chassis with 2x RP2, 2x ESP40 and 2x SIP40 (2x SPA-10G cards in the SIPs).
During the migration I completely followed the official Cisco instructions: https://www.cisco.com/c/en/us/td/docs/routers/asr1000/release/notes/xe-16-9/asr1000-rel-notes-xe-16-9.html#concept_zdm_2nx_5bb
Especially regarding the recommended ROMMON versions:
Cisco IOS XE ReleaseASR 1000 RP2ASR 1000-SIP40ASR 1000-ESP40
16.9.x16.9(5r)16.3(2r)16.3(2r)
All RPs run on IOS XE 16.9.3 and ROMMON Verion 16.9(5r).
All SIP40s run on ROMMON version 16.3(2r).
Only a few (not all) ESP40 can not be upgraded to 16.3(2r).
The following error message appears:
cp: omitting directory '/'
md5sum: /: Is a directory
md5sum: /bootflash/EFI/UpdateCapsule/UpdateCapsuleFile.bin: No such file or directory
Does anyone have any idea where the problem is or how to solve it?
Below you can see the whole CLI output:
Router#    sh ver
Cisco IOS XE Software, Version 16.09.03
Cisco IOS Software [Fuji], ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.9.3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Wed 20-Mar-19 08:02 by mcpre
Router# sh platform
0         ASR1000-SIP40       ok                    00:04:27
 0/0      SPA-1X10GE-L-V2     ok                    00:03:05
 0/2      SPA-1X10GE-L-V2     ok                    00:02:57
1         ASR1000-SIP40       ok                    00:04:27
 1/0      SPA-1X10GE-L-V2     ok                    00:03:05
 1/2      SPA-1X10GE-L-V2     ok                    00:02:53
R0        ASR1000-RP2         ok, active            00:04:27
R1        ASR1000-RP2         ok, standby           00:04:27
F0        ASR1000-ESP40       ok, active            00:04:27
F1        ASR1000-ESP40       ok, standby           00:04:27
P0        ASR1006-PWR-AC      ok                    00:03:56
P1        ASR1006-PWR-AC      ok                    00:03:55
0         00200800            16.3(2r)
1         00200800            16.3(2r)
R0        10021901            16.9(5r)
R1        10021901            16.9(5r)
F0        1003190E            16.2(1r)
F1        1003190E            15.3(3r)S
Thanks!
