ASR1K 5xE1 MFR Frame relay traffic not forwarding in one direction
 Dear Techies,
 Hope all is well !
Im doing this inter-op testing with Alcatel device for frame-relay and MFRs and got stuck at this situation which is actually mind boggling and I think i might be missing something "silly" :-(
Its a simple setup of
1. My ASR 1002-X with a LAN (Gig0/0/0) port is connected to a traffic generator.(ixia).
2. ASR WAN port is a 5xE1 bundled into a MFR circuit.
3. WAN link goes to a Alcatel box giving me my FR-DCE with E1s over MFR.
Issue is , I can send traffic to max throughput with  flow initiated from  LAN to WAN bit NOT the reverse flow initiated  from WAN side to LAN port. I see traffic coming into my 5xE1s (1.8 mbps each) but the traffic just wont go to the LAN side , somewhere it gets "stuck" or "dropped".
PING works fine from both sides.......but sending traffic is not possible !!
ASR CONFIG
controller SONET 0/3/0
 framing sdh
 clock source line
 aug mapping au-4
 au-4 1 tug-3 1
  mode c-12
  tug-2 1 e1 1 unframed
  tug-2 1 e1 2 unframed
  tug-2 1 e1 3 unframed
  tug-2 2 e1 1 unframed
  tug-2 2 e1 2 unframed
  tug-2 2 e1 3 unframed
 au-4 1 tug-3 2
  mode c-12
 au-4 1 tug-3 3
  mode c-12
interface MFR1
 no ip address
 encapsulation frame-relay IETF
 load-interval 30
 frame-relay multilink bid 10MB-PiPe
 frame-relay multilink bandwidth-class a
 frame-relay lmi-type ansi
interface MFR1.1 point-to-point
 ip address 10.10.17.2 255.255.255.0
 frame-relay interface-dlci 100
interface GigabitEthernet0/0/0
 no ip address
 load-interval 30
 negotiation auto
interface GigabitEthernet0/0/0.110
 encapsulation dot1Q 110
 ip address 11.11.11.1 255.255.255.0
interface Serial0/3/0.1/1/1/1:0
 no ip address
 encapsulation frame-relay MFR1
 frame-relay multilink lid First-Link
interface Serial0/3/0.1/1/1/2:0
 no ip address
 frame-relay multilink lid Second-Link
interface Serial0/3/0.1/1/1/3:0
 no ip address
 frame-relay multilink lid Third-Link
interface Serial0/3/0.1/1/2/1:0
 no ip address
 frame-relay multilink lid Fourth-Link
interface Serial0/3/0.1/1/2/2:0
 no ip address
 frame-relay multilink lid Fifth-Link
SDH_FR#sh frame-relay mul
SDH_FR#sh frame-relay multilink
Bundle: MFR1, State = up, class = A, fragmentation disabled
 BID = 10MB-PiPe
 Bundle links:
  Serial0/3/0.1/1/1/1:0, HW state = up, link state = Up, LID = First-Link
  Serial0/3/0.1/1/2/2:0, HW state = up, link state = Up, LID = Fifth-Link
  Serial0/3/0.1/1/2/1:0, HW state = up, link state = Up, LID = Fourth-Link
  Serial0/3/0.1/1/1/3:0, HW state = up, link state = Up, LID = Third-Link
  Serial0/3/0.1/1/1/2:0, HW state = up, link state = Up, LID = Second-Link
SDH_FR#
SDH_FR#
SDH_FR#
SDH_FR#sh fram
SDH_FR#sh frame-relay pvc 100
PVC Statistics for interface MFR1 (Frame Relay DTE)
DLCI = 100, DLCI USAGE = LOCAL, PVC STATUS = ACTIVE, INTERFACE = MFR1.1
  input pkts 8045          output pkts 8044         in bytes 515748
  out bytes 527920         dropped pkts 0           in pkts dropped 0
  out pkts dropped 0                out bytes dropped 0
  in FECN pkts 0           in BECN pkts 0           out FECN pkts 0
  out BECN pkts 0          in DE pkts 0             out DE pkts 0
  out bcast pkts 0         out bcast bytes 0
  5 minute input rate 1000 bits/sec, 2 packets/sec
  5 minute output rate 1000 bits/sec, 2 packets/sec
  pvc create time 01:07:58, last time pvc status changed 01:07:58
  fragment type end-to-end fragment size 1400
SDH_FR#
SDH_FR#
SDH_FR#
SDH_FR#
SDH_FR#
SDH_FR#
SDH_FR#ping 10.10.17.1-------------------------------------------------------------------------- THIS IS ALCATEL SIDE FROM TRAFFIC HAS TO COME.
Sending 5, 100-byte ICMP Echos to 10.10.17.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 3/3/4 ms
SDH_FR#
SDH_FR#
SDH_FR#sh frame-relay traffic
Frame Relay statistics:
        ARP requests sent 0, ARP replies sent 0
        ARP request recvd 0, ARP replies recvd 0
SDH_FR#
19
