ASR1k nat secondary addresses
I am having trouble configuring nat on an ASR1k and using secondary addresses on my outside interface.
interface GigabitEthernet0/0/0
description Outside Interface
ip address 222.222.159.14 255.255.255.128 secondary
ip address 222.222.159.1 255.255.255.128 secondary
ip address 222.222.159.2 255.255.255.128 secondary
ip address 222.222.159.3 255.255.255.128 secondary
ip address 222.222.159.4 255.255.255.128 secondary
ip address 222.222.159.5 255.255.255.128 secondary
ip address 222.222.159.6 255.255.255.128 secondary
ip address 222.222.159.67 255.255.255.224 secondary
ip address 222.222.150.166 255.255.255.252
ip nat outside
speed 100
no negotiation auto
cdp enable
ip virtual-reassembly
interface GigabitEthernet0/0/1
description Inside Interface
ip address 10.110.1.1 255.255.255.0
no ip proxy-arp
ip nat inside
negotiation auto
cdp enable
ip nat pool pool-159.1 222.222.159.1 222.222.159.1 netmask 255.255.255.128
ip nat pool pool-159.2 222.222.159.2 222.222.159.2 netmask 255.255.255.128
ip nat pool pool-159.14 222.222.159.14 222.222.159.14 netmask 255.255.255.128
ip nat pool pool-159.3 222.222.159.3 222.222.159.6 netmask 255.255.255.128
ip nat inside source list ip-nat-159.1 pool pool-159.1 overload
ip nat inside source list ip-nat-159.14 pool pool-159.14 overload
ip nat inside source list ip-nat-159.2 pool pool-159.2 overload
ip nat inside source list ip-nat-159.3 pool pool-159.3 overload
This blog states my exact problem.:
http://ccieplayground.wordpress.com/2010/03/30/asr1k-nat-really-does-not-like-secondary-addresses/
Are there any options that could make this work?  Something so simple that has worked on IOS devices for years now doesn't work?  Do I need to create vrf's with in the router?  Or perhaps make sub interfaces, but how do you apply same subnet addresses to multiple sub interfaces...?
Dan.
1 REPLY
Found out you are not supposed to put the secondary address on the interface at all.  Just setup your nat commands and it will work.  Like it does with an ASA
365
