10-27-2006 07:35 AM - edited 03-03-2019 02:29 PM
Here is the scenario. 4 2500 series routers 12.2 Enterprise Plus IOS
R1 Hub
R2 Spoke
R3 Spoke
Frm_Sw frame switch.
R1 can hit both spokes
both spokes can hit R1.
Spokes CANNOT hit each other. I am sure this is something very basic that i am missing, but I cant figure it out.
Rip V2 is running, split horizon is off on all routers.
Attached is my config... would appreciate some assistance.
10-27-2006 07:46 AM
just add one more frame relay map on both the spoke with the appropriate outgoing dlci with the other spoke ipaddress as destination...on local spoke
regards
Devang
10-27-2006 07:48 AM
You got it... right before you posted that.. i did that.. THANKS it works now.
I messed up and forgot to add that your response solved my issue... sorry. Hopefully an admin can fix that.
10-27-2006 07:53 AM
ya its my plasure but you can do it now... just kidding....
thanks for your rate...
regards
Devang
10-27-2006 07:46 AM
Please include your "Network" statements under "Router RIP"
Make sure you are advertise the right segments on teh right routers.
If this was a static routing situation, you put a static route on A, for B's network, by way of the hub ... and vice-versa
The hub knows where the spokes are because they are directly connected ... one spoke doesn't know where the other is because they can't see each other ... that's where the routing protocol does its work.
Make sure you have a "network" statement under Router RIP on both spoke routers, and that it's config'd for the right network address.
Good Luck
Scott
