ATM and FR conectivity
angel.batista
I'm configuring two routers for stablish comunication via WAN. My service provider is using MPLS and one router is using FR and other ATM.
The problem is that in both routers the interfaces are up but when I try to ping one interface from the same router, the interface (IP) don't respond.
The configuration is the following:
ROUTER A:
interface Serial0/0.738 point-to-point
ip address 192.168.20.1 255.255.255.252
no ip route-cache
no ip mroute-cache
no cdp enable
frame-relay interface-dlci 738
ROUTER B:
interface ATM0/1/0.738 point-to-point
ip address 192.168.20.2 255.255.255.252
no ip redirects
no ip unreachables
no ip route-cache
no ip mroute-cache
pvc 0/102
fnavarro
Hello Angel, I had the same issue before. First, ensure that the service provider supports cisco frame relay encapsulation (that is the default). If not, change the encapsulation type to ietf. Second, ensure that you are using the correct lmi type (ansi, cisco, or q933a). You currently have the interface configured with cisco encapsulation and lmi type. If the encapsulation and lmi type are correct, have the service provider ensure proper mapping of the dlci to atm vpi/vci.
7 Replies 7
just for my understanding, are you saying that you cannot ping the local interfaces, that is, 192.168.20.1 from ROUTERA, and 192.168.20.2 from ROUTERB ?
GP
First, Thanks Georg, for your help.
Yes, this is the problem, and if I can't ping my own interface I can't ping the other router.
What does a sh frame-relay map show on RouterA. From the Frame-relay side, you will not be able to ping your own interface. With out a mapping for IP to FR DLCI, you wont be able to ping the other end.
Read this faq.
http://www.cisco.com/warp/public/116/fr_faq.html
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Hello Angel,
this is just a guess, but try the following configuration on your ATM router:
interface ATM0/1/0
mtu 1500
no ip address
atm pvc 1 0 16 ilmi
atm uni-version 3.1
atm ilmi-keepalive 30
no ip proxy-arp
atm pvc 2 0 102 aal5snap inarp
If this does not work, can you post the output of 'show frame-relay map', on the FR router, and 'show atm pvc', on the ATM router ?
GP
fnavarro
Thanks to all for your time and help.
I changed encapsulation to IETF and the problem was resolve.
