Webcast-Catalyst9k
ATM behavior
I'm needing some engineering/ design help with ATM.
What I need to know is on an atm circuit with say 4 pvc's to four remote locations.
these pvc's are provisioned as UBR pvc's. Can I run up to the full bandwidth on any of the pvc's? or is the ATM t1 bandwidth split between the pvc's? If it is split that will mean that I can only run about 384k ( not including the cell tax) on each pvc.
1 REPLY
Hall of Fame Super Gold
Re: ATM behavior
Hi, there is no bandwidth split and each pvc will be free to burst up to the configured cell rate without relation to others. You can configure pvc's with different priority o so on case of congestion cells from the prioritized one will be sent first.
94
