Community Member
ATM int bouncing
i have these logs
May 13 10:51:40 extende: %ATM_AIM-5-ACTIVE_LINK_CHANGE: IMA Group ATM0/IMA1 now has 3 active links.
May 13 10:51:40 extende: %ATM_AIM-5-ACTIVE_LINK_UP: Interface ATM0/2/0 of IMA Group ATM0/IMA1 is now active.
May 13 10:51:40 extende: %ATM_AIM-5-ACTIVE_LINK_CHANGE: IMA Group ATM0/IMA1 now has 4 active links.
May 13 10:51:40 extende: %ATM_AIM-5-ACTIVE_LINK_DOWN: Interface ATM0/2/0 of IMA Group ATM0/IMA1 is now inactive.
May 13 10:51:42 extende: %ATM_AIM-5-ACTIVE_LINK_DOWN: Interface ATM0/2/0 of IMA Group ATM0/IMA1 is now inactive.
May 13 10:51:42 extende: %ATM_AIM-5-ACTIVE_LINK_CHANGE: IMA Group ATM0/IMA1 now has 3 active links.
May 13 10:51:42 extende: %ATM_AIM-5-ACTIVE_LINK_UP: Interface ATM0/2/0 of IMA Group ATM0/IMA1 is now active.
May 13 10:51:42 extende: %ATM_AIM-5-ACTIVE_LINK_CHANGE: IMA Group ATM0/IMA1 now has 4 active links.
May 13 10:51:44 extende: %ATM_AIM-5-ACTIVE_LINK_DOWN: Interface ATM0/2/0 of IMA Group ATM0/IMA1 is now inactive.
May 13 10:51:44 extende: %ATM_AIM-5-ACTIVE_LINK_CHANGE: IMA Group ATM0/IMA1 now has 3 active links.
May 13 10:51:44 extende: %ATM_AIM-5-ACTIVE_LINK_UP: Interface ATM0/2/0 of IMA Group ATM0/IMA1 is now active.
May 13 10:51:44 extende: %ATM_AIM-5-ACTIVE_LINK_CHANGE: IMA Group ATM0/IMA1 now has 4 active links.
May 13 10:51:53 extende: %ATM_AIM-5-ACTIVE_LINK_DOWN: Interface ATM0/2/0 of IMA Group ATM0/IMA1 is now inactive.
May 13 10:51:53 extende: %ATM_AIM-5-ACTIVE_LINK_CHANGE: IMA Group ATM0/IMA1 now has 3 active links.
May 13 10:51:53 extende: %ATM_AIM-5-ACTIVE_LINK_UP: Interface ATM0/2/0 of IMA Group ATM0/IMA1 is now active.
May 13 10:51:53 extende: %ATM_AIM-5-ACTIVE_LINK_CHANGE: IMA Group ATM0/IMA1 now has 4 active links.
May 13 10:51:54 extende: %ATM_AIM-5-ACTIVE_LINK_DOWN: Interface ATM0/2/0 of IMA Group ATM0/IMA1 is now inactive.
May 13 10:51:54 extende: %ATM_AIM-5-ACTIVE_LINK_CHANGE: IMA Group ATM0/IMA1 now has 3 active links.
May 13 10:51:54 extende: %ATM_AIM-5-ACTIVE_LINK_UP: Interface ATM0/2/0 of IMA Group ATM0/IMA1 is now active.
May 13 10:51:54 extende: %ATM_AIM-5-ACTIVE_LINK_CHANGE: IMA Group ATM0/IMA1 now has 4 active links.
May 13 10:52:06 extende: %ATM_AIM-5-ACTIVE_LINK_DOWN: Interface ATM0/2/0 of IMA Group ATM0/IMA1 is now inactive.
May 13 10:52:06 extende: %ATM_AIM-5-ACTIVE_LINK_CHANGE: IMA Group ATM0/IMA1 now has 3 active links.
May 13 10:52:06 extende: %ATM_AIM-5-ACTIVE_LINK_UP: Interface ATM0/2/0 of IMA Group ATM0/IMA1 is now active.
May 13 10:52:06 extende: %ATM_AIM-5-ACTIVE_LINK_CHANGE: IMA Group ATM0/IMA1 now has 4 active links.
May 13 10:52:08 extende: %ATM_AIM-5-ACTIVE_LINK_DOWN: Interface ATM0/2/0 of IMA Group ATM0/IMA1 is now inactive.
May 13 10:52:08 extende: %ATM_AIM-5-ACTIVE_LINK_CHANGE: IMA Group ATM0/IMA1 now has 3 active links.
May 13 10:52:08 extende: %ATM_AIM-5-ACTIVE_LINK_UP: Interface ATM0/2/0 of IMA Group ATM0/IMA1 is now active.
May 13 10:52:08 extende: %ATM_AIM-5-ACTIVE_LINK_CHANGE: IMA Group ATM0/IMA1 now has 4 active links.
May 13 10:52:13 extende: %ATM_AIM-5-ACTIVE_LINK_DOWN: Interface ATM0/2/0 of IMA Group ATM0/IMA1 is now inactive.
May 13 10:52:13 extende: %ATM_AIM-5-ACTIVE_LINK_CHANGE: IMA Group ATM0/IMA1 now has 3 active links.
May 13 10:52:14 extende: %ATM_AIM-5-ACTIVE_LINK_UP: Interface ATM0/2/0 of IMA Group ATM0/IMA1 is now active.
May 13 10:52:14 extende: %ATM_AIM-5-ACTIVE_LINK_CHANGE: IMA Group ATM0/IMA1 now has 4 active links.
Telco says problem at customer end
how should i procedd?
Hall of Fame Super Gold
Re: ATM int bouncing
Begin with show controllers and check clock config, what exact hardware is that?
You can place the circuit in loop then the burden is on telco to prove the circuit OK.
Community Member
it is router
sh ver
Cisco IOS Software, 3800 Software (C3825-ADVIPSERVICESK9-M), Version 12.4(9)T1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Wed 30-Aug-06 19:26 by prod_rel_team
Cisco 3825 (revision 1.1) with 221184K/40960K bytes of memory.
Processor board ID FTX1036A14M
2 Gigabit Ethernet interfaces
8 Serial interfaces
8 ATM interfaces
8 Channelized T1/PRI ports
1 Virtual Private Network (VPN) Module
2 ATM/Voice AIMs
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
62720K bytes of ATA System CompactFlash (Read/Write)
if i do sh controller which option i should use as Router has ATM interfaces
thanks
Show controllers T1 or E1 depending on what you have. Also under controller you would set the loopback local.
Community Member
hi
thanks for reply
sh controller t1
h controller t1
T1 0/1/0 is up.
Applique type is Channelized T1
Cablelength is long gain36 0db
No alarms detected.
alarm-trigger is not set
Soaking time: 3, Clearance time: 10
AIS State:Clear LOS State:Clear LOF State:Clear
Version info Firmware: 20060711, FPGA: 13, spm_count = 0
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (139 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
5693 Line Code Violations, 6 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 1 Line Err Secs, 0 Degraded Mins,
0 Errored Secs, 0 Bursty Err Secs, 1 Severely Err Secs, 0 Unavail Secs
T1 0/1/1 is down.
Transmitter is sending remote alarm.
Receiver has loss of signal.
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 139 Unavail Secs
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 86400 Unavail Secs
T1 0/2/0 is up.
No alarms detected.
Version info Firmware: 20060623, FPGA: 20, spm_count = 0
Data in current interval (143 seconds elapsed):
T1 0/2/1 is up.
No alarms detected.
what next i can do
from this output do u see any errors as per
Telco issue is with our device
Community Member
Also i have this
T1 0/3/0 is up.
No alarms detected.
T1 0/3/1 is up.
No alarms detected.
No errors. Are the IMA messages continuously happening ? Did the IMA group ever worked properly ?
Community Member
thanks for reply
yes it was working fine before.
Community Member
hi this is log right now
May 15 10:50:16 extende: %SEC-6-IPACCESSLOGP: list DCOMinA denied tcp 10.39.6.16(88) -> 10.39.2.226(1171), 2 packets
May 15 10:50:37 extende: %SEC-6-IPACCESSLOGP: list DCOMinA denied tcp 10.39.3.7(445) -> 10.39.6.16(1117), 1 packet
packets
May 15 16:24:54 extende: %ATM_AIM-5-ACTIVE_LINK_CHANGE: IMA Group ATM0/IMA1 now has 3 active links.
May 15 16:24:54 extende: %ATM_AIM-5-ACTIVE_LINK_UP: Interface ATM0/2/0 of IMA Group ATM0/IMA1 is now active.
May 15 16:24:54 extende: %ATM_AIM-5-ACTIVE_LINK_CHANGE: IMA Group ATM0/IMA1 now has 4 active links.
May 15 16:25:01 extende: %ATM_AIM-5-ACTIVE_LINK_DOWN: Interface ATM0/2/0 of IMA Group ATM0/IMA1 is now inactive.
May 15 16:25:01 extende: %ATM_AIM-5-ACTIVE_LINK_CHANGE: IMA Group ATM0/IMA1 now has 3 active links.
May 15 16:25:01 extende: %ATM_AIM-5-ACTIVE_LINK_UP: Interface ATM0/2/0 of IMA Group ATM0/IMA1 is now active.
May 15 16:25:01 extende: %ATM_AIM-5-ACTIVE_LINK_CHANGE: IMA Group ATM0/IMA1 now has 4 active links.
May 15 16:25:02 extende: %ATM_AIM-5-ACTIVE_LINK_UP: Interface ATM0/2/0 of IMA Group ATM0/IMA1 is now active.
May 15 16:25:02 extende: %ATM_AIM-5-ACTIVE_LINK_CHANGE: IMA Group ATM0/IMA1 now has 4 active links.
May 15 16:25:03 extende: %ATM_AIM-5-ACTIVE_LINK_DOWN: Interface ATM0/2/0 of IMA Group ATM0/IMA1 is now inactive.
May 15 16:25:03 extende: %ATM_AIM-5-ACTIVE_LINK_CHANGE: IMA Group ATM0/IMA1 now has 3 active links.
May 15 16:25:03 extende: %LINK-3-UPDOWN: Interface ATM0/2/0, changed state to down
May 15 16:25:03 extende: %ATM_AIM-5-ACTIVE_LINK_UP: Interface ATM0/2/0 of IMA Group ATM0/IMA1 is now active.
May 15 16:25:03 extende: %ATM_AIM-5-ACTIVE_LINK_CHANGE: IMA Group ATM0/IMA1 now has 4 active links.
May 15 16:25:04 extende: %ATM_AIM-5-ACTIVE_LINK_DOWN: Interface ATM0/2/0 of IMA Group ATM0/IMA1 is now inactive.
May 15 16:25:04 extende: %ATM_AIM-5-ACTIVE_LINK_CHANGE: IMA Group ATM0/IMA1 now has 3 active links.
May 15 16:25:04 extende: %ATM_AIM-5-ACTIVE_LINK_UP: Interface ATM0/2/0 of IMA Group ATM0/IMA1 is now active.
May 15 16:25:04 extende: %ATM_AIM-5-ACTIVE_LINK_CHANGE: IMA Group ATM0/IMA1 now has 4 active links.
May 15 16:25:05 extende: %LINK-3-UPDOWN: Interface ATM0/2/0, changed state to up
May 15 16:25:16 extende: %SEC-6-IPACCESSLOGP: list DCOMoutA permitted udp 10.39.115.94(0) -> 10.39.3.7(0), 1 packet
May 15 16:25:16 extende: %SEC-6-IPACCESSLOGP: list DCOMinA denied tcp 10.39.6.16(389) -> 10.39.2.185(1171), 2 packets
May 15 16:28:16 extende: %SEC-6-IPACCESSLOGP: list DCOMinA denied tcp 10.39.6.16(135) -> 10.39.115.56(1117), 2 packets
One possibility is that some data structure has corrupted and causing the instability. An in-depth look would be needed to see what exactly is going wrong.
Or you can upgrade to the latest of 12.4(9)T and reboot at the next occasion. Chances are, it will go away.
Community Member
Thanks for your Reply
i will give it a shot
thanks
405
