ATM interface counting CRCs
All,
I've my ATM interface counting errors.
I replaced the MM fiber cable, the interface and even the VXR slot, but it still count input errors and CRCs:
ATM1/0 is up, line protocol is up
Hardware is ENHANCED ATM PA
MTU 4470 bytes, sub MTU 4470, BW 149760 Kbit, DLY 80 usec,
reliability 255/255, txload 16/255, rxload 17/255
Encapsulation ATM, loopback not set
Encapsulation(s): AAL5
4095 maximum active VCs, 521 current VCCs
VC idle disconnect time: 300 seconds
0 carrier transitions
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 01:14:43
Input queue: 0/75/1/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: Per VC Queueing
30 second input rate 10109000 bits/sec, 2602 packets/sec
30 second output rate 9567000 bits/sec, 2608 packets/sec
7745535 packets input, 3633707969 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
23 input errors, 42 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
7764336 packets output, 3445163989 bytes, 0 underruns
Re: ATM interface counting CRCs
Thanks very very much for your respond.
I found something in the PDFs that makes sence in my case: --> my router aggregates customers (subinterfaces) --> i think that this might made a buffer problem resulting in CRCs.
What's your comment ?
216
