ATM link erroring
jsheriony
we've been working to isolate what has been causing the errors on the WAN.It has been tested to the DSU clean.
Can please someone check if there's any possible issue with the config?It's a
DS3 link.
version 12.3
service timestamps debug uptime
service timestamps log uptime
hostname
boot-start-marker
boot-end-marker
logging buffered 4096 debugging
enable password cisco
voice-card 0
dspfarm
no aaa new-model
ip subnet-zero
ip cef
no ip domain lookup
interface FastEthernet0/0
description
ip address 176.3.1.1 255.255.255.0
speed 100
full-duplex
no cdp enable
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface ATM1/0
mtu 1500
bandwidth 5000
no ip address
load-interval 30
atm scrambling cell-payload
no atm ilmi-keepalive
interface ATM1/0.1 point-to-point
description
ip address 172.32.1.2 255.255.255.0
pvc 2/33
vbr-nrt 5000 4000 100
oam-pvc manage 0
encapsulation aal5snap
router eigrp 110
redistribute connected
redistribute static
network 172.32.1.0 0.0.0.255
default-metric 64 100 250 250 1500
no auto-summary
ip http server
ip classless
access-list 1 permit 172.*.*.* 0.0.0.255
no cdp run
snmp-server community
snmp-server host 10.*.*.*
snmp-server host 130.*.*.*
line con 0
exec-timeout 5 0
password
logging synchronous
login
line aux 0
exec-timeout 0 0
password
logging synchronous
login
modem InOut
transport input all
flowcontrol hardware
line vty 0 4
access-class 1 in
exec-timeout 5 0
password
logging synchronous
login
ntp clock-period 17207680
ntp server 172.31.10.2
end
2 Accepted Solutions
Hi!
SFP mismatches mean a mismatch with LR / SR ( long-range/ short range ) etc. Did you try using an attuneor ? If you dont have it right now, try fitting in the cables loosely. Pull them out so that the link is just up ( dont insert the cable tightly. Sometimes the problem could arise due to a short cable length causing more power (light) to be transmitted saturating the rx interface. The best way to verify this problem is to measure the power recieved in the other end of the cable and checking whether it satisfies the power criteria for the interfaces. I donot remember the exact values ( have to be searched ).
Niranjan
Hi, the point it that loopback alone is not enough sometime.
For the circuit to test clean, you need a bert testing with either controller loopback, or physical (tx to rx with cable).
Do this first, any serious telco must be able to do a bert testing.
17 Replies 17
n.nandrekar
Level 4
Level 4
What is the config on the other side?
What are the errors seen?
Is the MTU on the other side too set to 1500, as the default mtu on ATM is not 1500.
Can you give the outputs of
sh int atmxxxx
sh controllers atm xxxx
sh atm int atm xxxx
Niranjan
Niranjan,
thank you for the assistance.
The other side's MTU is also 1500
here's the output
#sh controllers ATM1/0.1
Interface ATM1/0 is up
Hardware is RS8234 ATM DS3
LANE client MAC address is 0011.9355.3290
hwidb=0x82DEE034, ds=0x82DEF820
RS8234 base 40800000, ds 82DEF820, PM5346 base 40C00000, slave base 40C00000
SBDs - avail 2047, guaranteed 0, unguaranteed 2047, starved 0 rbds 4098
Seg VCC SCH access timeout 0
Seg VCC table 4080DD80, Shadow Seg VCC Table 82E1B2A4, VCD Table 82E312D0
Schedule table 40818D80, Shadow Schedule table 82E382FC, Size FC1
RSM VCC Table 4094F180, Shadow RSM VCC Table 82F3FCB0
VPI Index Table 4084C700, VCI Index Table 4084F180
Bucket2 Table 4082C900, Shadow Bucket2 Table 82E3C22C
MCR Limit Table 4082CD00, Shadow MCR Table 82E3DE58
ABR template 4082CF00, Shadow template 827FC748
RM Cell RS Queue 4084D180
RBD OIR array 82DF2598, HBD OIR array 82DF0598
LECID Table 4084CF00, Host LECID Table 82DF6F68, LECID Table Bitmask 0
Queue TXQ Addr Pos StQ Addr Pos
0 UBR 40848F00 0 079B4F80 0
1 UBR PLUS 40849300 0 079B5780 0
2 UBR TUN1 40849700 0 079B5F80 0
3 UBR TUN2 40849B00 0 079B6780 0
4 UBR TUN3 40849F00 0 079B6F80 0
5 ABR 4084A300 0 079B7780 0
6 VBR NRT 4084A700 97 079B7F80 96
7 VBR RT 4084AB00 0 079B8780 0
8 VBR/ABR TUN1 4084AF00 0 079B8F80 0
9 VBR/ABR TUN2 4084B300 0 079B9780 0
10 VBR/ABR TUN3 4084B700 0 079B9F80 0
11 SIG 4084BB00 0 079BA780 0
12 CBR 4084BF00 0 079BAF80 0
13 VPD 4084C300 0 079BB780 0
Queue FBQ Addr Pos RSQ Addr Pos
0 OAM 4095B180 255 079BC040 0
1 UBR 4095C180 0 079BD040 0
2 UBR PLUS 4095D180 0 079BE040 0
3 UBR TUN1 4095E180 0 079BF040 0
4 UBR TUN2 4095F180 0 079C0040 0
5 UBR TUN3 40960180 0 079C1040 0
6 ABR 40961180 0 079C2040 0
7 VBR NRT 40962180 240 079C3040 16
8 VBR RT 40963180 0 079C4040 0
9 VBR/ABR TUN1 40964180 0 079C5040 0
10 VBR/ABR TUN2 40965180 0 079C6040 0
11 VBR/ABR TUN3 40966180 0 079C7040 0
12 SIG 40967180 0 079C8040 0
13 CBR 40968180 0 079C9040 0
PCI bus err 0, DMA fifo full err 0, RSM parity err 0
RSM sync err 0, RSM/SEG Q full err 0, RSM overflow err 0
RSM stat Q full err 0, no free buff Q err 0, RSM ignore rbd CPI count 0
RSM ignore rbd CPI&PAD count 0, RSM ignore rbd abort count 0
RSM ignore rbd unknown count 0, pdu_check flag 0x0, error flag 0x0
SEG stat Q full err 0, SEG underflow err 0
Framer Chip Type PM7345
Framer Chip ID 0x20
Framer State RUNNING
--More-- Defect Status NO ERRORS
Loopback Mode NONE
Clock Source INTERNAL (but the source of this clock is derived from LINE)
DS3 Scrambling ON
Framing DS3 C-bit direct mapping
TX cells 77718531
TX bytes 4119082143
Last output time 3d15h
RX cells 38572497
RX bytes 3244131389
Last input time 3d15h
Line Code Violations (LCV) 172811929
DS3: F/M-bit errors 2699395
DS3: parity errors 419
DS3: path parity errors 319
DS3/E3: G.832 FEBE errors 28499419
T3/E3: excessive zeros 172707266
uncorrectable HEC errors 82
idle/unassigned cells dropped 0
LCV errored secs 2637
DS3: F/M-bit errored secs 2645
DS3: parity errored secs 12
DS3: path parity errored secs 12
T3/E3: excessive zeros errored secs 2637
DS3/E3: G.832 FEBE errored secs 3040
uncorrectable HEC errored secs 9
LCV error-free secs 311244
DS3: F/M-bit error-free secs 311236
DS3: parity error-free secs 313869
DS3: path parity error-free secs 313869
T3/E3: excessive zeros error-free secs 311244
DS3/E3: G.832 FEBE error-free secs 310841
uncorrectable HEC error-free secs 313872
PM 7345 registers (base 0x40C00000):
cfgr 0x00, ier 0x08, isr 0x00, ctlr 0x00,
imrr 0x21, dlcr 0xF8, rboc_cier 0x38, rboc_isr 0x3F,
t3frmr_cfgr 0x01, t3frmr_ier 0x03, t3frmr_isr 0x00, t3frmr_statr 0x20,
rfdl_cfgr 0x84, rfdl_esr 0x80, rfdl_statr 0x87, rfdl_datar 0x87,
pmon_pmr 0x00, pmon_iesr 0x03, pmon_lcvec0r 0x00, pmon_lcvec1r 0x00,
pmon_fbeec0r 0x00, pmon_fbeec1r 0x00, pmon_sezdc0r 0x00, pmon_sezdc1r 0x00,
pmon_peec0r 0x00, pmon_peec1r 0x00, pmon_ppeec0r 0x00, pmon_ppeec1r 0x00,
pmon_febeec0r 0x00, pmon_febeec1r 0x00, t3tran_cfgr 0x07, t3tran_diagr 0x00,
xfdl_cfgr 0xC0, xfdl_isr 0xC2, xfdl_txdatar 0xC0, xboc_coder 0xFF,
splr_cfgr 0x00, splr_ier 0x00, splr_isr 0x00, splr_statr 0x02,
splt_cfgr 0x00, splt_ctlr 0x00, splt_diagr 0x00, splt_f1r 0x00,
cppm_locmr 0xFC, cppm_copmr 0xF0, cppm_b1ec0r 0x00, cppm_b1ec1r 0x00,
cppm_feec0r 0x00, cppm_feec1r 0x00, cppm_febec0r 0x00, cppm_febec1r 0x00,
cppm_hcsec0r 0x00, cppm_hcsec1r 0x00, cppm_iucc0r 0xFF, cppm_iucc1r 0xFF,
cppm_rcc0r 0x4D, cppm_rcc1r 0x01, cppm_tcc0r 0x03, cppm_tcc1r 0x0E,
rxcp_ctlr 0x2C, rxcp_frcr 0x01, rxcp_iesr 0x00, rxcp_iucph1r 0x00,
rxcp_iucph2r 0x00, rxcp_iucph3r 0x00, rxcp_iucph4r 0x01, rxcp_iucmh1r 0xFF,
rxcp_iucmh2r 0xFF, rxcp_iucmh3r 0xFF, rxcp_iucmh4r 0xFF, rxcp_upcph1r 0x00,
rxcp_upcph2r 0x00, rxcp_upcph3r 0x00, rxcp_upcph4r 0x00, rxcp_upcmh1r 0xFF,
rxcp_upcmh2r 0xFF, rxcp_upcmh3r 0xFF, rxcp_upcmh4r 0xFF, rxcp_hcscsr 0xFC,
rxcp_lctctr 0xB4, txcp_ctlr 0xA4, txcp_iesr 0x18, txcp_iucph1r 0x00,
txcp_iucph2r 0x00, txcp_iucph3r 0x00, txcp_iucph4r 0x01, txcp_iucph5r 0x52,
txcp_iucpr 0x00, e3frmr_foptr 0x00, e3frmr_moptr 0x00, e3frmr_fier 0x00,
--More-- e3frmr_fiisr 0x01, e3frmr_meier 0x00, e3frmr_meiir 0x00, e3frmr_mesr 0x00,
e3tran_foptr 0x00, e3tran_sdoptr 0x03, e3tran_bip8emr 0x00, e3tran_maoptr 0x00,
ttb_ctlr 0x04, ttb_ttisr 0x00, ttb_iar 0x00, ttb_idr 0x00,
ttb_eptlr 0x00, ttb_ptlcsr 0x00, sffpcsr 0x31, pcr 0x30,
here's the sh run at the other side......
version 12.2
service timestamps debug datetime localtime show-timezone
service timestamps log datetime localtime show-timezone
service password-encryption
hostname
enable secret
ip subnet-zero
no ip domain-lookup
call rsvp-sync
description
ip address 192.168.80.2 255.255.255.0
speed 10
full-duplex
no cdp enable
interface ATM1/0
mtu 1500
no ip address
load-interval 30
atm framing cbitplcp
description
bandwidth 5000
ip address 172.32.1.1 255.255.255.0
pvc 1/32
oam-pvc manage 0
router eigrp 110
redistribute rip
network 172.32.2.0 0.0.0.255
no auto-summary
router rip
version 2
redistribute static
redistribute eigrp 110
network 192.168.80.0
default-metric 1
no auto-summary
ip classless
ip route 176.3
ip http server
no cdp run
snmp-server enable traps tty
snmp-server host
snmp-server host
dial-peer cor custom
line con 0
exec-timeout 5 0
password
logging synchronous
login
line aux 0
exec-timeout 0 0
password
logging synchronous
login
modem InOut
transport input all
line vty 0
access-class 1 in
exec-timeout 0 0
password
logging synchronous
login
line vty 1 4
access-class 1 in
exec-timeout 5 0
password
logging synchronous
login
ntp clock-period 17208108
ntp server ******
end
Line Code Violations (LCV) 172811929 <<<<
DS3: F/M-bit errors 2699395 <<<
DS3/E3: G.832 FEBE errors 28499419 <<<<<
T3/E3: excessive zeros 172707266 <<<<<
Have you checked the power on the line? Can you use a attinuator and check? Check for the interface type/ SFP mismatches.
check for the power recieved and if it is saturating the other interface.
this is a good pointer :
http://www.cisco.com/en/US/products/hw/modules/ps2033/products_tech_note09186a00801087d0.shtml
Niranjan
Niranjan,
thank you very much??
can you be please a little more specific??
SFP mismatches???
what could be suspected on this issue??specifically..
Is there way to have it fixed by changing some
configs??
Thanks a lot...
Hi!
Niranjan
Niranjan,
thank you verymuch for the advise....
We'll try working on it with your advise...
Hi, your DS3 interface being of the electrical type does not use optical module or cables.
The errors seen are likely due to a faulty circuit and you should have the SP fix it.
Mr. Bevilacqua,
thank you very much for the advise.
How can you tell by looking at my outputs
that they are electrical type or not optical module or cables...
I'm sorry, I'm not that technical...
You mean to say the electrical signals are not too strong or low which has been probably causing the errors??
We tested it again last night for 4 hours...
Up to DSU, it was clean....it's already very critical...
I would appreciate if you would be able to give me more advise and maybe more specific...
Again, thank you
E3/T3 are always electrical, with coaxial BNC connectors. How long is the cable to the DSU, perhaps the singal is too "hot" and you could try an attenuator inline.
DS3 cable is just 1m.
We shut down the LAN port and did the ping test the other night, it was OK.But when we
started to run the traffic, the ping drops started again.
We've been observing AAL5 length violations on the CE.
We're running out of options...
Is the attenuator a good option?
If the signal is too hot, why do we have it clean when we have the LAN port shutdown.
Thank you very much for assistance..
Hi, circuits may show clean but start giving trouble as soon traffic is present.
Search for "bnc inline attenuator", you don't need the expensive ones, anything will do.
That will not fix the issue if the circuit is indeed faulty. To prove this you would need telco do a bert testing, comparing results with DSU loopback and router controller loopback.
