Gold
ATM PVC between Lucent & Cisco
Anyone know of any problems or restrictions concerning configuring an atm pvc between a lucent switch and a cisco mgx ?
Silver
Re: ATM PVC between Lucent & Cisco
An ATM interface might stick in the state "going down" if the PVC is created from the ATM router module with VCI "34" on the ATM side. For example, "atm pvc 2 35 pd on interface ATM0/0/0 7 34" causes the line to flap "up" and "down". Refer the URL
http://www.cisco.com/en/US/products/hw/switches/ps718/prod_release_note09186a008041fac6.html#wp826935
What are the traffic parameters (PVC type like CBR UBR VBR ABR, PVC settings like PCR, SCR, burst sizes, etc., OAM management, ILMI management)? Make sure they are matching. The MGX follows the standard parameters from the ATM forum externally.
What line parameters are required? Make sure they match. Besides those "match conditions" ATM should behave fine.
Regards, Martin
188
