09-27-2005 02:10 AM - edited 03-03-2019 10:36 AM
Hi . I've configured a simple ppp chap dsl o POTS with cisco 877 router. I can't figure out why is the ATM0 and ATM0.2 down and the dialer 0 down when i have a similar config on a cisco 837 that is working . PLease help
Solved! Go to Solution.
09-27-2005 04:54 AM
which IOS version are you running ? If possible, try c870-advipservicesk9-mz.123-14.YT, and see if that makes a difference.
Also, try 'dsl operating-mode ansi-dmt' instead of 'auto'. And configure 'no atm ilmi-keepalive', as well as 'no atm ilmi-pvc-dicovery'.
GP
09-27-2005 04:54 AM
GP
09-27-2005 06:37 AM
Hi GP.
Great help. you save my day. Thanks .
was just dsl operating-mode ansi-dmt instead of auto.
But i change all the rest now . good friend.
cheers . Pedro Baptista
