Auto QoS VoIP Command on WAN Router Serial Interface
I can't find a document that shows what actually happens when the the auto qos voip command is applied to an interface. Anyone know where I can find one? Also, do I need to add a service-policy output command to the interface or does this happen automatically? If I have to add it manually, where do I get the name of the service policy to add to the end of the command?
1 ACCEPTED SOLUTION
Re: Auto QoS VoIP Command on WAN Router Serial Interface
Hi Patrick
You don't need to define service policy under the interface while configuring Auto QOS.
You just need to enable auto qos voip in the interface mode service policies will be created automatically..
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080500b8f.html
regds
1 REPLY
Hi Patrick
regds
133
