Webcast-Catalyst9k
auto qos
I enable the auto qos on the WAN link. When I enable the SDM to monitor it. There is "default class data" only. I select the "nuber of packet tx". The result is the same. below is default "auto qos" config. I change the bandwidth setting only. Any missing in the config?
BTW, why there is "rmon" is enabled automatically. what is it? what happen if I remove it?
rdgs
! R1 config
policy-map AutoQoS-Policy-Trust
class AutoQoS-VoIP-RTP-Trust
priority percent 50
class AutoQoS-VoIP-Control-Trust
bandwidth percent 5
class class-default
fair-queue
interface Serial1/0
no cdp enable
service-policy output AutoQoS-Policy-Trust
rmon event 33333 log trap AutoQoS description "AutoQoS SNMP traps for Voice Drops" owner AutoQoS
Re: auto qos
Anita,
You have enabled auto qos - fine, BUT are you marking any packets to classify for the QoS priority?
rmon - is nothing to worry about right now, you need to figure out:-
1) How much bandwdith of the serial interface is being used.
2) Where you are marking the VoIP traffic
3) What you want to define in the class-default.
Below is the SRND for QoS, I suggest you read it:-
http://www.cisco.com/en/US/netsol/ns656/networking_solutions_program_home.html
http://www.cisco.com/en/US/docs/solutions/Enterprise/WAN_and_MAN/QoS_SRND/QoS-SRND-Book.html
HTH?
Re: auto qos
1. the b/w is 20M
2. It seems that I haven't marked the voip traffic
3. class-default is for data, not for voip
I have 3 x AS54 router Voip gateway. All of them are standard config for dial-peer (pots and voip).
how do I mark the voip packet?
Base on the config (no mark the voip packet), can voip go to pri-q? any QoS service can be provide by the WAN link only?
rdgs
Re: auto qos
Did you read the URL I posted previously??
If your outgoing interface is the serial interface - then a good place to mark the traffic is as close to the source as possible i.e the switch port.
If you are unable to mark that close, then I suggest you mark on the LAN interface if your router.
One more thing - if you have a 20mbs circuit, why are you trying to apply QoS? Remember priority queuing for QoS will only work when "congestion" occurs - does your 20mbs circuit ever reach 100%???
You need to look into Policing and shapping of traffic in the interface if you are having VoIP quality issues.
HTH>
Re: auto qos
I read the doc, some of them I understand what it address. It does not mention how to mark the voip packet on AS54 router. It mentions to enable the "auto qos voip" on LAN switch. Does it mean that the packet should be marked on layer 2 to be more effectively?
I enable the QoS on AS54, below is the command I work on. Does it work? any missing?
! R2 AS5400
class map VOIP
match ip access-group 10
set dscp ef
policy map QOS
class VOIP
priority 80
access-list 10 permit 172.16.10.1
interface GE 0/0
ip address 172.16.10.1 255.255.255.0
serice-policy output QOS
dial-peer voice 8601 voip
ipv4: 192.168.128.1
dial-peer voice 8602 voip
ipv4: 192.168.128.2
BTW, anything I need to aware after I enable the "auto qos voip" on switch? (e.g. in router, we may tune the b/w setting after auto qos voip is enable)
rdgs
Re: auto qos
You are matching in 172.16.10.1 - which is the ip address of the GE 0/0 interface. Nothing truly originates from the interface - so NO QoS.
This will NOT work - you need to match on:-
- The source LAN IP Subnet
or
Protocol (using NBAR)
or
TCP/UDP port numbers
or
DSCP value in the Layer 3 IP header.
HTH>
Re: auto qos
the default gateway of AS54 is 172.16.10.254. there is no WAN link on AS54. the source ip of voip traffic is 172.16.10.1.
Is the QoS working?
rdgs
Re: auto qos
So just let me get this straight....
The router with the QoS configure on it - does NOT have a WAN link attached. You are placing QoS on a gig ethernet interface - when your 20mbs circuit does no actually connect to the router where you want to apply QoS...... that is NOT possible.
You need to get a better understanding of QoS - I suggest you re-read the link I posted, and read teh below:-
http://www.cisco.com/en/US/docs/internetworking/technology/handbook/QoS.html
NO - the QoS is not working.
HTH>
Re: auto qos
that doc is related the queue design and QoS.
May I ask a question directly?
1. It is not necessary to config QoS on AS54, is it? If not, any sample config for me to reference
rdgs
Re: auto qos
OK to answer you question - what interfaces are connected on the AS54 device? Do you have a WAN connection? Or is it just a LAN connection? if it is just a LAN connection - what is the speed 100mbs or 1gbs??
QoS is used for congestion management and priority of specific traffic. Are you really seeing congestion on your LAN?
Please read the QoS SRND guide - this tells you everything you need to know about QoS, what it is desgined for, where you should deploy - network designs etc.
You cannot just turn QoS on - expect it to work and fix issues, if you don't even know if you need it.
HTH>
Re: auto qos
The GE is connected to AS54 and there is no WAN. The WAN is connected to 76 router. They (76 and AS54) are on the same segment. There is no congestion in LAN. the speed is 1G.
Base on the cisco suggestion, the marking should be near to source. Why config the QoS on LAN switch, not on the AS54? Is it related to performance issue?
If I use another model of switch (e.g. 3COM or Dlink) as core switch, do router support the QoS which 3Com marking?
I am not expert on QoS, that's why I seek for someone help to solve my concern and question.
rdgs
Re: auto qos
I am not expert on QoS. Could anyone help me?
rdgs
Re: auto qos
Have you read the previously attached URL's?
167
