automatic WAN fail-over
rgenovesi
Looking for the right solution for automatic WAN failover for a small office that has T1 and DSL WAN connections.
I understand that route metrics can be used to switch connections if an interface physical fails, but is there anyway to achieve the same goal if something further upstream on one of the connections fails?
I'm looking for something a little more robust than interface-down fail-over and any suggestions would be appreciated. I am concerned with outbound only traffic, so no need to worry about inbound.
thanks.
2 Accepted Solutions
amit-singh
Level 8
Level 8
You can go for reliable static route object tracking if your ISP allows you to do so.
Please check the following link.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5413/products_feature_guide09186a00801d862d.html
HTH, Please rate if it does.
-amit singh
Here's a config I have used successfully to achieve this:
Replace with an IP that you can ping through your main link - preferably the ISP side of the WAN link address.
interface Ethernet 0/0
description Primary Link
ip address 10.1.1.1 255.0.0.0
interface Serial0:1
description Backup Link
ip address 192.168.1.1 255.0.0.0
rtr 1
type echo protocol ipIcmpEcho
timeout 1000
frequency 3
threshold 2
rtr schedule 1 life forever start-time now
track 100 rtr 1 reachability
access list 101 permit icmp any host echo
route map LOCAL_POLICY permit 10
set ip next-hop 10.1.1.254
set interface null0
ip local policy route-map LOCAL_POLICY
ip route 0.0.0.0 0.0.0.0 10.1.1.254 track 100
ip route 0.0.0.0 0.0.0.0 192.168.1.254 254
Hope that helps - pls rate the post if it does.
Paresh
12 Replies 12
kamalnathsingh
Try Cisco OER option
amit-singh
Level 8
Level 8
-amit singh
If I'm reading this right it is just what I'm looking for:
Basically an ICMP ping test to a specified host/gateway, which if fails the routing table is updated to use the back up link.
I have to reread again to make sure I have this right and if so will rate accordingly.
Thanks!
interface Serial0:1
rtr 1
timeout 1000
frequency 3
threshold 2
set interface null0
Paresh
Sir,
I am desperately looking for a solution for auto fallback from Ethernet to Dialer, since Ethernet never goes down with the help of floating static route dialer doesn't fire. When I was going thru your post, I think it would work for me a great instant.
I tried to implement this solution at one of location where Ethernet connectivity thru Radio is primary and ISDN is backup. The site having router 1721 and the ios is c1700-advsecurityk9-mz.123-5e.bin
But, In the router "rtr" commands doesn't support.
Can you pls tell me which IOS version support all the commands mentioned in your post.
I hope you understood my question.
Thanks in Advance
rgds,
Hardik..
Hi Hardik,
YOu might want to upgrade to at least 12.3(11)T - all of the feature sets in those releases support reliable static route backup...
Paresh
Thanks for your answer,
I am still having one problem !!
Let me explain the scenario. At my central side, Router ----> Ethernet Radio ----->
This Ethernet Radio is point to multipoint. Multiple locations are statically routed from central router towards Ethernet Radio.
I can apply above configuration(mentioned in post) to one of my far Radio's, What kind of configuration should i put to my central Router ? Since the router is having diff. subnets for diff far end Routers. Also I understand "ip local policy" can be applied only one time in a router. will it work without ip local policy ??
rgds,
Hardik..
Hi Hardik,
You can certainly use the reliable static route feature at the central in your case. Instead of tracking default routes, associate a different tracking object with each of your static routes. For your local policy, you can use something like the following:
match ip address 101
set interface null0
access-list 101 permit ip any
Paresh
Thanks yet again !!
I will implement the same and will post the response.
rgds,
Hardik..
sorry some correction
Following cisco 1721 ios supports rtr command
c1700-entbasek9-mz.124-5.bin
Dear Sir,
I Really like your solution.
but i want to know two more things.
I tell you my scenario :
my commectivity is primary : Ethernet
Secondary : ISDN
my Ethernet remote site to first my Customer end Radio Device & then to POP Radio & from this it terminated to my router.
All are configured with static route.
Please replay me..
Thanks in Advance.
Yogesh
nedian123
hi,
Amit is right, but when you are using FR based WAN FR- End to End keep alive (EEK) will help you.
for more details.....
http://www.cisco.com/en/US/products/sw/iosswrel/ps1830/products_feature_guide09186a0080087a58.html
NOTE:plz vote if this helps.
Akhtar
