12-18-2013 07:34 AM - edited 03-04-2019 09:53 PM
Howdy,
I've a Cisco 1841 with both WAN ports in use FE 0/0 FE 0/1
First FE 0/0 has a MPLS connection with my internet provider. 2MB/2MB DL/UL
Second FE 0/1 Has an internal MPLS with one of our server storage provider. 1MB/1MB DL/UL
The thing is, I have a second internet connection wired in a low cost router for emergencies. I want to centralize all the services in the 1841.
It is possible to configure AUX port for a third ADSL connection and load balancing between ADSL1 (FE 0/0) and ADSL2 (future AUX port) 2MB/2MB DL/UL
Or need another router?
Thanks in advance,
Solved! Go to Solution.
12-18-2013 08:24 AM
Hi Miguel,
You'll need the WIC-1ADSL for the said additional WAN connection.
The AUX port is usually connected to an external modem for remote management.
12-18-2013 08:24 AM
Hi Miguel,
12-18-2013 09:28 AM
Thank you johnlloyd_13 for your quick response.
