01-12-2018 05:05 AM - edited 03-05-2019 09:44 AM
I have a few IPSec tunnels between my Cisco router and my Amazon AWS VPCs (using the AWS VPC VPN functionality). I have always just downloaded the suggested configuration from the AWS VPN for Cisco and modified it for my router. I am no Cisco expert and I was wondering why the neighbor statements appear under both the "router bgp" section as well as the "address-family"? Is there a specific reason for this? Or is it possible for the neighbor statements only to appear once under the address-family section?
router bgp 65000
neighbor 169.254.0.1 remote-as 7224
neighbor 169.254.0.1 activate
neighbor 169.254.0.1 timers 10 30 30
address-family ipv4 unicast
neighbor 169.254.0.1 soft-reconfiguration inbound
Thanks!
Solved! Go to Solution.
01-12-2018 06:17 AM
its a newer style of BGP called MBGP which has extensions , the BGP process can be broken down into multiple different sections , they need to be in both sections the neighbor statements anyway but you shouldn't need to activate it under main area but only under ipv4 section
so we have the same setup but we also use address-family ipv4 vrf xxx for iwan and ISPs will also have another section for there PE -PE communication address-family vpnv4 unicast
https://www.cisco.com/c/en/us/td/docs/ios/12_2/iproute/command/reference/fiprrp_r/1rfmbgp.html
probably the best explanation ive seen it described anyway from Peter in another post below
01-12-2018 06:17 AM
01-14-2018 11:09 PM
Thanks a lot for the clarification Mark!
