09-09-2014 01:30 PM - edited 03-04-2019 11:43 PM
I've been looking for some way to failover to a backup VPN connection in case our primary Metro-Ethernet connection goes down. So far, I haven't really found anything that will work. The closest solution I've found is somehow using either Enhanced Object Tracking or Backup Interface with floating static routes, but I'm getting confused and not sure it's possible for our situation.
We have a single Cisco 1921 router at a branch location with 2 connections to headquarters. We'd like to configure the 1921 router with both connections and have one of them be a backup/failover connection. The primary circuit is a 4Mbps Metro-Ethernet connection, and the second (backup/failover) connection is a site-to-site VPN over a single E-1 line.
Is it somehow possible to have the Metro-Ethernet connection on GE0/1 be a primary connection to headquarters with the site-to-site VPN connection on Serial0/0/0 be a failover or backup connection? The GE0/0 interface connects to the branch office LAN. Attached is a diagram to help with clarity.
Solved! Go to Solution.
09-09-2014 02:15 PM
Hey Jeff,
Static floating route is easiest and simplest to configure to achieve what you are looking. However if you want to do some load balancing you may check the following link:https://supportforums.cisco.com/document/32186/dual-internet-links-nating-pbr-and-ip-sla
HTH.
RS.
09-09-2014 02:15 PM
Hey Jeff,
HTH.
RS.
