Backup Interface
Hello All
Maybe a easy one but I need to ask :)
I have 2 Leased Lines on 2811.
One of them will be a backup data line.
(for example serial 0 and serial 1
Serial 1 will be a backup data line)
Where should I put backup interface command and how ?
Thx for helping
Ersin
Hall of Fame Super Silver
Re: Backup Interface
Hello Ersin,
under the primary interface
see
http://www.cisco.com/en/US/tech/tk801/tk379/technologies_configuration_example09186a0080093fc4.shtml
You can tune some parameters like timers or load threshold
important: the backup interface cannot be used for other purposes it will be held down and rised when primary fails (or load is over threshold)
Hope to help
Giuseppe
Go to interface Serial 1 and issue the command -if)# backup interface serial 0
Hello Rahul,
It should be the opposite
int ser 0
backup interface ser1
Hope to help
Giuseppe
Hello Giuseppe ,
You are right ..
Thanks for the update
Rahul
127
