Backup ISDN auto disconnected
I would know if there is a command that permit to configure auto disconnect the backup isdn interface, after that the interface try for 3 times to connect without success.
enc
Re: Backup ISDN auto disconnected
I am not able to test this, but it might be an idea:
On serial interfaces you can use " dialer enable-timeout" with a max value of 2147483 which is a lot of days.
You can not use this command with the purpose you have direcly on an ISDN interface, but I would expect you could use is on a Dialer interface.
(ISDN interfaces are not held down after a call has failed or completed because these interfaces support several possible calls at a time)
interface Dialer1
description ISDN
bandwidth 64
ip address
encapsulation ppp
dialer pool 1
dialer idle-timeout 180
dialer enable-timeout 2147483
dialer string 1234567890
dialer-group 1
interface BRI1/0
no ip address
encapsulation ppp
dialer pool-member 1
Thanks you for answer. Now I'm studing the command dialer enable-timeout... if there is good news I'll write here ;)
At Serial interface try "backup interface dialer0" and set delay to get dialer to be fired by "backup delay 5 5" both commands to be configured at serial interface also put floating static routes i.e 0.0.0.0 0.0.0.0 Serial 0
0.0.0.0 0.0.0.0 dialer 0 50
This will enable the backup configuration
and put the "dialer ideal-timeout 100" at dialer interface.
Hope this can help u out.
rgds,
Hardik..
127
