Community Member
backup solution for wan
Hi all
we are looking at the options for a backup circuit to our primary 2 meg e1 connection.
the options we are looking at are, 4 isdn lines, vpn over a business broadband circuit, or vpn over sdsl circuit.
can anyone suggest the best ot use here ?
cheers
Carl
Silver
Re: backup solution for wan
Carl
If you go with the ISDN then it will be more preferable.
regadrs
shivlu
Super Bronze
8x 64 Kbps ISDN?
VPNs over Internet?
Broadband bandwidth, up and down? Any SLA?
SDSL bandwidth? Any SLA?
Community Member
I would suggest ISDN.
Is that real time traffic? If yes, then go for "ISDN PRI" for backup circuit to your primary 2 meg e1 connection. It's enough to carry the payload of your traffic.
Goutam
Community Member
hi,Carl
if isdn is choosed,
you only need to pay for isdn when the primary link down and isdn become up.
regard
dongdong
280
