backup (vpn) connection for MPLS
edward.borst
Currently we have a managed mpls network to our branch offices.
For this we want to create a backup link via VPN.
The MPLS is outsourced, and the routers are not maintained by us.
the question is what is a good design for this?
I'm thinking of building a vpn between our own routers, but I'm struggeling what best option is.
Some help is needed.
Attached I have a very simple diagram.
Edward
Hello Edward,
You havnt mentioned how your are connecting to the PE routers.- statically or IGP/BGP?
The vpn backup link is a good idea, however given that your primary will want to be over the mpls cloud, you will have to consult with your provider before any implementation, As there is a good chance of  using this newly created vpn link  as the primary path.
Your provider may need to apply a sham link connection on their PE routers so you can manipulate your traffic path and then it does indeed cross the mpls instead of the newly created vpn backup link.
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
I forgot to tell that!
Currently all routes are static. no bgp is used on our site.
Edward
Hello Edward,
One possible solution then would be to use additional static's with admin distances and object-tracking
res
Paul
Thanks.
Kind Regards
Paul
edward.borst
And what about using DMVPN to create a backup vpn for the WAN?
What kind of dynamic routing do you prefer (in combination with DMVPN)?
Any other possibilities?
