BAD E1 controller?
horvaia
I have a NM-2CE1U= network module.
S/N:26568717 and it seems that one
controller on this network modul is
malfunctioning. The line protocol
on the interface is constantly in down
status. I've tested already all the
variation of the port. I made a local
loopback and I wasn't able to see the loop on the interface. Before the loop no data came in or went out on the interface. The another E1 controller on
this netwrok module works fine. Has anyone met this problem before?
What should I do?
Thanks in advance,
Andras
8 Replies 8
thisisshanky
Level 11
Level 11
What router is in question ? Also paste a sh diag and sh version output ?
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Thanks for your reply, here are the informations:
sh diag:
Slot 2:
CE1 (Unbalanced) Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware revision 1.1 Board revision D0
Serial number 26568717 Part number 800-02117-04
FRU Part Number: NM-2CE1U=
Test history 0x0 RMA number 00-00-00
EEPROM format version 1
EEPROM contents (hex):
0x20: 01 3B 01 01 01 95 68 0D 50 08 45 04 00 00 00 00
0x30: 68 00 00 00 01 10 27 00 FF FF FF FF FF FF FF FF
sh ver:
IOS (tm) 3600 Software (C3660-IS-M), Version 12.2(31), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Thu 11-Aug-05 15:44 by tinhuang
Image text-base: 0x60008940, data-base: 0x611A0000
ROM: System Bootstrap, Version 12.0(6r)T, RELEASE SOFTWARE (fc1)
ROM: 3600 Software (C3660-IS-M), Version 12.2(31), RELEASE SOFTWARE (fc2)
panther uptime is 4 weeks, 4 days, 1 hour, 48 minutes
System returned to ROM by reload at 07:36:11 CEST Sat Nov 5 2005
System restarted at 07:37:03 CEST Sat Nov 5 2005
System image file is "slot0:c3660-is-mz.122-31.bin"
cisco 3660 (R527x) processor (revision 1.0) with 51200K/14336K bytes of memory.
Processor board ID JAC0550A11H
R527x CPU at 225Mhz, Implementation 40, Rev 10.0, 2048KB L2 Cache
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Primary Rate ISDN software, Version 1.1.
3660 Chassis type: ENTERPRISE
2 FastEthernet/IEEE 802.3 interface(s)
17 Serial network interface(s)
12 Channelized E1/PRI port(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
20480K bytes of processor board PCMCIA Slot0 flash (Read/Write)
can you also include show controllers e1 o/p in ur post ?
status during normal conditions as well as during looped condition so that it can be checked out for the possible alarms/errors..
regds
See the attached information. The strange thing is that
I can't see any error on the interface. The indicator
led also doesn't show any error both in loop or
in normal operation mode. Just the line protocol doesn't come up. This interface was a member in a
multilink bundle and once it has gone
without any CRC etc... and I have checked the
physicall line with the telco... so this problem
seems me very strange...
(at this time the tests was made locally)
Since you are using ppp as encapsulation and its in a bundle i dont thin u will get ur interface status as up up..we did have faced the same kinda issues but thats with normal NM-8AS card.
But i would suggest you to change the encapsulation to HDLC on that serial link and check for loop.
before doing that do backup ur whole config as well the particular interface config..
i think that should atleast help to get a point isolated and help to move further.
regds
hi
i was pointing that during looped condition and if ur serial interface is configured in a multilink bundle you may not see the loop..
regds
ok. sorry.
Well I changed the encapsualtion on the interface but
I still can't see the loop. This is very strange...
The problem is I can't see the loop on the
interface but in normal operation I would see the
loop on it if I put a loop on it. And I even don't
know where to search regarding this problem.
