Bandwidth Issue
Hello All:
I'm having a problem with bandwidth and really can't figure out why. Quick background. 3MB RF circuit running through a CISCO SOHO and terminating in a Sonicwall Firewall.
Bandwidth test from inside the LAN - intially you'll get about 3mb but it quickly fades to 70KB.
Test in front of the firewall - full 3 mb. Behind FW - 70KB. Now one would assume it's the FW. I swapped it out for a spare and same results. Cabling was also swapped out. I cannot for the life of me figure where to go with this. Interfaces on SOHO look clean. Config is below
Any help would be greatly appreicated.
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip name-server 209.178.200.2
ip name-server 209.178.223.4
interface Ethernet0
description CRWS Generated text. Please do not delete this:209.178.228.129-255.255.255.224
ip address 209.178.228.129 255.255.255.224 secondary
ip address 10.10.10.1 255.255.255.0
no ip mroute-cache
no cdp enable
hold-queue 32 in
interface Ethernet1
ip address 209.178.206.49 255.255.255.0
no ip mroute-cache
duplex auto
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 209.178.206.1
ip http server
no ip http secure-server
no cdp run
control-plane
line con 0
exec-timeout 120 0
no modem enable
transport preferred all
transport output all
stopbits 1
line aux 0
line vty 0 4
exec-timeout 120 0
password 7 09464F070C16
login
length 0
transport input all
scheduler max-task-time 5000
end
Hall of Fame Super Gold
Re: Bandwidth Issue
why don't you pursue the issue with the "sonic firewall" vendor ?
Re: Bandwidth Issue
I have and there are no issues with the FW. I have also just eliminated it this morning by going out to straight out through the router. Same issue
Silver
Re: Bandwidth Issue
Are you getting any errors on the interfaces? Can you show us the results of SHOW INTERFACE command.
Re: Bandwidth Issue
Did you check the speed & duplex setting on your Firewall Interfaces ? are they taking any errors ?
HTH - pls rate all useful posts
Re: Bandwidth Issue
I have tried mixing and matching port settings on the FW. I have never played with a SOHO before and I have found that on the WAN Ethernet port, there are no settings for speed or duplex. I am guessing it just defaults to auto detect. But, this may be the issue. Going to swap out the router and if that doesn't fix it.....I don't know where to go with this.
Re: Bandwidth Issue
Over a 24 hr period, I am seeing 8 CRC errors and 25 output drops. I can't see this as having the effect that we are seeing??
Re: Bandwidth Issue
Not really. Your problem may be with the firewall. why don't try a cisco one.
285
