Bandwidth Limit
I want to know is it possible to limit the bandwith or define it for a vlan on 6500 series or 3750 Mpls series.
Regards B.Mozaffari
Re: Bandwidth Limit
It is possible by applying Ratelimit / Policing ( based on the IOS )on teh Layer 3 Interface
Bronze
Re: Bandwidth Limit
yep..u can achive this by using the rate-limiting / police command.
I would suggest that you use policing alongwith the concerned policymaps as it works much efficeintly .
create policy map and apply it to the interface and within this policy map you wil have to define the rate.
rate if this helps u.
119
