bandwidth limiting
paulkilcoyne
Hi Guys,
hope this finds you all well.
I have a 3845 Router with three connected interfaces, one to my WAN, one to my LAN and another to my wifi zone. I want to limit the amount of WAN bandwidth the WIFI zone can take to say a max of one third and not restrict WAN bandwidth from the LAN at all.
Is this possible?
Paul
7 Replies 7
Hi Paul ,
You can use CAR on the interface to Wifi zone.
Interface x/y
rate-limit input ...
rate-limit output ...
or CB policing
policy-map WIFI-IN
class class-default
   police cir 20000
policy-map WIFI-OUT
class class-default
   police cir 20000
int x/x
service-policy WIFI-IN in
service-policy WIFI-OUT out
Dan
Hi Dan,
thanks for the reply. I'd like to keep this as simple as possible so here goes;
So assuming my wan bandwidth is 50meg and I want to limit wifi to 1/4 (12.5meg) of this then on my wifi interface I do the following:
int gi 0/0
rate-limit input 12500000 ( bits per sec )
rate-limit output 12500000
So now wifi connected via gi 0/0 can only download a max of 12.5meg/sec and the same for uploading.
Is this correct?
Thanks again,
Paul
Hi Paul ,
I suppose that you have also some traffic from WIFI to LAN is that correct.
Because with this configuration you will limit all the traffic from WIFI
Dan
Hi Dan,
I see your point. Is there a better solution?
Paul
Yes , using CAR with access-list , and dening the traffic from WIFI to LAN.
rate-limit input access-group 100
rate-limit output access-group 101
ip access-list extended 100
deny ip wifi-net lan-net
permit ip any any
ip access-list extended 101
deny ip lan-net wifi-net
permit ip any any
Dan
Hi Dan,
so it doesn't matter about wifi to lan traffic. Here is the config I'm using:
rate-limit output 3000000 562500 1125000 conform-action transmit exceed-action drop
rate-limit input 3000000 562500 1125000 conform-action transmit exceed-action drop
How does it look to you?
I don't really understand the "Normal burst bytes" and "Maximum burst bytes" terms but I followed a post and calculated these as follows:
Normal burst bytes = configured rate/8 * 1.5 seconds
Maximum burst bytes = configured rate * 2
Am I limiting the bandwidth up and down to 3meg?
Paul
Hi Paul,
Yes. You are using the recommanded values. Normal burst amoung of traffic in bytes send on each time interval ( 1.5 seconds ). Maximum burst is the exceeded traffic. You can disable this by setting Maximum burst to the Normal burst value. Even like this you have exceed-action drop.
Yes using those values you are limiting the traffic to 3mbps. You can check your rate-limiting with show interface Fa0/0 rate-limit
Dan
