Bandwidth on 3725
I have a 3725 router and I need help doing the following
I need to monitor our DS3 usage.
I also need to limit the bandwidth to about 10 Megs.
Please advise
Hall of Fame Super Gold
Re: Bandwidth on 3725
To monitor, suggest you prtg (search) that is free for personal use up 1 router.
To limit bandwidth, if you own both sides of the link, enter under interface "dsu bandwidth . But, to not waste the link is better to limit only certain traffic using a shape or rate-limit command that is done via QoS (a little more advanced).
Hope this helps,please rate post if it does!
As paul mentioned you can make use of prtg since its gonna be a single interface.
http://www.paessler.com/prtg
You can also monitor the traffic on the link/port using show interface command and check out the same...
regds
230
