04-02-2007 01:23 AM - edited 03-03-2019 04:22 PM
I have to design a network for offshore storage.
5GB data would need to be copied over an IPLC link daily.
Considering the latency between the circuits to be 280ms, how should i calculate to size the bandwidth requirement
04-02-2007 01:38 AM
You can make use of the below link to find out the approx time required to download the same..
http://www.t1shopper.com/tools/calculate/downloadcalculator.shtml
regds
04-02-2007 06:49 AM
You also need to know the application that will be transferring/receiving the data. Throughput is controlled in the application level, you can have the biggest internet pipe in the world but if your application can only push/receive data maximum of 1KB per second, it defeats the purpose.
