Bandwidth Restriction on each port Layer 3750 Layer 3 Switch
I have a Cisco 3750 layer 3 switch. I want to limit the bandwidth to 1 Mbps on each port of switch. Can i do that & if yes then How ?
Please let me know
Re: Bandwidth Restriction on each port Layer 3750 Layer 3 Switch
Friend,
You can use policing to limit the bandwidth.
Switch(config)# access-list 1 permit any
Switch(config)# class-map ipclass1
Switch(config-cmap)# match access-group 1
Switch(config-cmap)# exit
Switch(config)# policy-map flow1t
Switch(config-pmap)# class ipclass1
Switch(config-pmap-c)# police 1000000 8000 exceed-action drop
Switch(config)# interface gigabitethernet2/0/1
Switch(config-if)# service-policy input flow1t
have a look at this link
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12225see/scg/swqos.htm#wp1044737
HTH, rate if it does
Narayan
Thanks a lot Sir,
I am able to control the input traffic on the port with about said configuration. But when I applly service-policy on output of port, it says that "Warning: Assigning a policy map to the output side of an interface not supported"
Please let me know how to apply service policy on output of port.
Sulekh Nain
Silver
Alternatively, you can do it over class-default, without using Access List.
eg:
policy-map LIMIT_1M
class class-default
interface range gigabit 1/0/1 - 24
service-policy input LIMIT_1M
Thanks a lot Sir,
I am able to control the input traffic on the port with about said configuration. But when I apply service-policy on output of port, it says that "Warning: Assigning a policy map to the output side of an interface not supported"
Sulekh Nain
Hall of Fame Super Bronze
827
