Webcast-Catalyst9k
Bandwidth Usage by Routing Protocol & Keep-alive (Important Information)
Hello All,
We have BGP & OSPF in our Network. Also we have implemented "Keepalive" command for the VPN Link.
Since the VPN Link is for Backup Purpose but i see approxmiate usage of 50 kbps / 100 kbps of Link Usage on Continuous Basis.
Is this Usage because of Routing Protocol Updates & Continuous Keepalive Packets sent on Link ? ?
Kindly adivce on the Same. Awaiting for your earlier Updates.
Best Regards,
Guru Prasad R
Bronze
Re: Bandwidth Usage by Routing Protocol & Keep-alive (Important
Yes , you are correct.
BR,
Bjornarsb
Thanks for your Confirmation.My suspection was correct. Is there any Document showing this Information ? ?
Best Regards,
Guru Prasad R
312
