09-21-2007 04:57 AM - edited 03-03-2019 06:52 PM
All, I have a 2801 and a 3800 routing WAN Traffic. At both ends, I have a SAN that we do replication with. My Question, I can I throttle the bandwidth or control how much bandwidth that the replication uses?
09-21-2007 05:07 AM
hi
AFAIK with SAN replication process around for seamless replication process you need high bandwidth between the locations to support the same.
do revert back on how much bandwidth you currently have between the sites and what kinda reservation plans you have in mind ..
regds
09-21-2007 07:04 PM
You should be able to either. As long as you can identify the SAN traffic from your other traffic, you can police/shape it (which sets a bandwidth maximum), define a minimum bandwidth guarantee, do both, or prioritize it so that it only use excess bandwidth.
10-12-2007 11:38 AM
All, I have a 3mbps line. How would I limit the amount of bandwith the SAN would use, using a 2801 Router.
Thank you for your help.
10-12-2007 04:00 PM
NB: Not sitting at a Cisco box, so syntax will likely be incorrect.
ip access-list extended SAN_Traffic
remark match traffic to/from SAN IP addr
permit ip any host (SAN IP ADDR)
permit ip host (SAN IP ADDR) any
class-map SAN_Traffic
match group SAN_Traffic
policy-map CBWFQ
class SAN_Traffic
!limit max to 1 Mbps and minimum 1 Mbps
!adjust to suit
shape (1 Mbps)
bandwidth (1 Mbps)
or
policy-map CBWFQ
class SAN_Traffic
!allow usage all all bandwidth
!but only guarantee 1% of link
!i.e. other traffic will get most of the link
!adjust to suit
bandwidth percentage 1
interface serial 0
service-policy out CBWFQ
