bandwithlimit on a egress port - cat2960
hi,
i have a 2960 switch, on whic i have to limit the bandwith on port fa0/25 to 100kb/s.
i tried the command "srr-queue bandwith limit 10" and defined "bandw 1000" on the fa0/24.
so 10% of 1000kb/s is 100kb/s - but there was no effekt
any idea ?
Hall of Fame Super Gold
Re: bandwithlimit on a egress port - cat2960
Switches are not the best tool to limit bandwidth. Sometime they work, sometime they don't.
I suggest you use a router to limit bandwidth, or make this question again in the LAN forum (this one is WAN0.
hi,
thanks for answer.
i configured it like it is described with the
"srr-queue bandwidth limit" command.
the problem ( i think) is that the switch does not react on the "bandwith" command.
it always says it is a 100mb/s interface and
the range for limiting is from 10 to 100%
so the minimum bandwidth i can shape is 10mb/s.
does anybody know if this is right or is there a command where the switch looks at the "bandwith" command ??
thanks for any answer
Hi rabeder,
The 2960 should support "srr-queue bandwidth limit" however you're correct in saying that the minimum rate is 10% so the lowest you can shape to is 1Mbps if you force the interface to 10Mbps full duplex.
"srr-queue bandwidth limit" limits based on a percentage of the physical line rate - it is not related to the "bandwidth" interface command.
If you want shaping to a granularity of 100kbps then you should be looking at a router to do this as mentioned by p.bevilacqua.
Brad
Ratings appreciated.
293
