Banner motd
smothuku
Level 7
Level 7
Hi All ,
I know that Banner motd can be used to display message when we try to access router.
If i want to display ten lines using banner motd which command i should use.I tried on 3640 router but i am able to see only three lines after configuring it with banner motd.
Is there any special command so that i can get 10 lines whenever i try to access router.
satish
smothuku
Level 7
Level 7
HI All,
Thanks ....i got it....
ankbhasi
Hi Satish,
Can you confirm the IOS version you are running on your router. Banner Motd should display all lines and I remember a bug for the same.
Please post the IOS version on 3640.
Ankur
Hi Satish,
Try the below command
banner login ^C
Your Message
^C
I have made config to display 11 lines. I am using IOS 12.0 and above
S. Shantharam
