Basic BGP config PLZ help me
HI eveyone. I am perparing myself for CCNP. I am trying to do basic BGP config. but i am not able to do EBGP config with loopback interfaces.
R3(6100)------------------------>R4(5500)----------------------R5(6500)
R4(config)#int loop 4
R4(config-if)#ip address 4.4.4.4 255.255.255.255
R5(config)#int loop 5
R5(config-if)#ip address 5.5.5.5 255.255.255.255
Step 2 – Created static routes on each router to the new addresses
R4(config)#ip route 5.5.5.5 255.255.255.255 10.1.45.1
R5(config)#ip route 4.4.4.4 255.255.255.255 10.1.45.2
!--- By adding static route.
Step 3 – Configure BGP neighbors using eBGP multihop
R4(config)#router bgp 5500
R4(config-router)#neighbor 5.5.5.5 remote-as 6500
R4(config-router)#neighbor 5.5.5.5 update-source loopback 4
R4(config-router)#neighbor 5.5.5.5 ebgp-multihop 2
!--- Allows eBGP neighbor relationship with an IP address (loopback 5) 2 hops away
R5(config)#router bgp 6500
R5(config-router)#neighbor 4.4.4.4 remote-as 5500
R5(config-router)#neighbor 4.4.4.4 update-source loopback 5
R5(config-router)#neighbor 4.4.4.4 ebgp-multihop 2
In my BGP routing table, I got RIB failure for 5.5.5.5 and 4.4.4.4 loopback entry. In sh routing route, i can see 5.5.5.5 and 4.4.4.4 connected via static rotues. So there is rib failure in BGP. loopbacks are not learing route via BGP.  if i change AD on static route with AD 255 then route come into BGP and no more RIB failure. but still EBP ping doesnt work from internal router R3 to R5 because there is no static route.
Please help me. I am stuck here. As i can see in book and CBT nuggets that we use static routes and EBP multihop between EBP neigbhour. then network can ping. in my case if routing table has static route then RIB failure. if loopback with BGP then still nuthing work.
1 ACCEPTED SOLUTION
harjeet,
I'm not sure this is the problem but routers 4 and 5 are next to each other, thus not multiple hops away????
Tony
harjeet,
Tony
Hi tony
  R4-R5 are next to each other. but they are not directly connected BGP neighbours because they are connected via loopback ebgp config. so you have to use command ebgp multihop on EBGP config. i have posted all topology with detail below under cadet alain profile.
Re: Basic BGP config PLZ help me
do u have physical interfaces configured?
Purple
don't worry about the rib-failure, it simply means that the BGP table tried to inject this prefix into the RIB table but as it was learned via another protocol with a better AD, it couldn't.
To verify your eBGP peering between loopbacks: sh ip bgp summary and you should see a number at the far right side.
if you change your static route AD it means this route is not believable so it won't get installed in the RIB, don't do this as you need L3 connectivity to bring up your BGP peering.
Concerning R3 to R5: the first condition for a BGP prefix to be advertised and also to be installable in the RIB table is the next-hop must be reachable , you can verify it with the sh ip bgp output which should have a > sign on the far left side.
We don't have full BGP config here as there is no network or redistribute command so which prefix are you advertising?
for a ping from r3 to r5, you must advertise the r3-r4 subnet on r3 and the r4-r5 subnet on r5 because pinging from r3 will source the packet from r3-r4 interface.
So post following on all 3 routers:
- sh run | s bgp
- sh ip bgp summ
-sh ip bgp
-sh ip route
Regards.
Alain
HI Alain
  Thanks for reply. Sorry i didnt explain you whole  topology before. I am using GNS3 IOS 3600, I saw EBGP config with  loopback on cbt nugget video (Jeremy Cioara) and same on BSCI book. They  configured EBP connection with loopback ip address rather than directly  connected physical interfaces ip addresses. I did same as cbt.
R3----------(IBGP 6500)---------R2-----------(EBGP 6100)--------------R6      (TOPOLOGY)
There is EBGP connection between R2--R6 (EBGP 6100)  with loopback neighbors. According to lab, I configured static routes  between R2--R6 routers because loopbacks are not directly connected.  also i put command EBGP multihop 4.
FOr IBGP 6500 connection i have configured R3--R2 routers. config below
(R2)
interface Loopback3
ip address 2.2.2.2 255.255.255.0
router bgp 6500
  no synchronization
  bgp log-neighbor-changes
  network 2.2.2.0 mask 255.255.255.0
  neighbor 3.3.3.3 remote-as 6500
  neighbor 3.3.3.3 update-source Loopback3
  neighbor 3.3.3.3 next-hop-self
ip route 6.6.6.0 255.255.255.0 Serial1/1
(R3)
interface Loopback3
ip address 3.3.3.3 255.255.255.0
router bgp 6500
no synchronization
network 3.3.3.0 mask 255.255.255.0
neighbor 2.2.2.2 remote-as 6500
neighbor 2.2.2.2 update-source Loopback3
For EBGP config R2----R6 are configured
(R2)
router bgp 6500
neighbor 6.6.6.6 remote-as 6100
neighbor 6.6.6.6 ebgp-multihop 4
neighbor 6.6.6.6 update-source Loopback3
(R6)
interface Loopback6
ip address 6.6.6.6 255.255.255.0
router bgp 6100
no synchronization
network 6.6.6.0 mask 255.255.255.0
network 30.0.0.0 mask 255.255.255.0    -----------also loopback (30.0.0.1)
neighbor 2.2.2.2 ebgp-multihop 4
neighbor 2.2.2.2 update-source Loopback6
ip route 2.2.2.0 255.255.255.0 Serial1/1
After all this configuration, it should work as i saw in jermay's video. but mine is not working.
There is sucessful ping between R2--IBGP--R3 and R2--EBGP--R6. but i cant ping from R3---R6.
R_3#sh ip bgp
BGP table version is 7, local router ID is 40.0.0.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal, r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*>i2.2.2.0/24       2.2.2.2                  0    100              0     i         -----  (IBGP route)
*> 3.3.3.0/24       0.0.0.0                  0               32768      i
*>i6.6.6.0/24       2.2.2.2                  0    100      0            6100  i  ------(EBGP route)
*>i10.0.0.0/24      2.2.2.2                  0    100      0            i
*>i30.0.0.0/24      2.2.2.2                  0    100      0           6100  i -------(EBGP advertised route)
*> 40.0.0.0/24      0.0.0.0                  0               32768     i
R_3#ping 6.6.6.6
Sending 5, 100-byte ICMP Echos to 6.6.6.6, timeout is 2 seconds:
Success rate is 0 percent (0/5)
R_3#ping 30.0.0.1
Sending 5, 100-byte ICMP Echos to 30.0.0.1, timeout is 2 seconds:
R_6#sh ip bgp
BGP table version is 18, local router ID is 30.0.0.1
r> 2.2.2.0/24       2.2.2.2                  0             0         6500    i ----------(Rib failure)
*> 3.3.3.0/24       2.2.2.2                                0          6500   i
*> 6.6.6.0/24       0.0.0.0                  0                        32768 i
*> 10.0.0.0/24      2.2.2.2                  0             0        6500   i
*> 30.0.0.0/24      0.0.0.0                  0                       32768 i
*> 40.0.0.0/24      2.2.2.2                                0         6500   i
R_6#ping 3.3.3.3
Sending 5, 100-byte ICMP Echos to 3.3.3.3, timeout is 2 seconds:
R_6#ping 2.2.2.2
Sending 5, 100-byte ICMP Echos to 2.2.2.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 8/23/32 ms
R_2#sh ip bgp
BGP table version is 14, local router ID is 20.0.0.1
*> 2.2.2.0/24       0.0.0.0                  0                  32768   i
*>i3.3.3.0/24       3.3.3.3                  0    100                0   i
r> 6.6.6.0/24       6.6.6.6                  0                         0  6100 i -------(Rib failure)
*> 10.0.0.0/24      0.0.0.0                  0                 32768   i
*> 30.0.0.0/24      6.6.6.6                  0                        0   6100 i
*>i40.0.0.0/24      3.3.3.3                  0    100               0   i
I can see BGP didnt inject route in routing table on R2--R6 because AD is good on static routes.
R_2#sh ip route
20.0.0.0/24 is subnetted, 1 subnets
C       20.0.0.0 is directly connected, Loopback2
     6.0.0.0/24 is subnetted, 1 subnets
S       6.6.6.0 is directly connected, Serial1/1 -----------static routes
     172.17.0.0/30 is subnetted, 1 subnets
R_3#traceroute 6.6.6.6
Tracing the route to 6.6.6.6
  1 172.16.2.1 20 msec 32 msec 20 msec (ip address of R2 interface directly connected to R3)
  2  *  *  *
Please advise me, why my network is not working. i did same as i saw in  CBT. Exactly same. Network is not pinging from R3--R6 and there is rib  failure on EBGP. I cant go ahead untill i fix this. i tried my best to explain it. if you need any info please ping me. waiting for reply.
harjeet
Harjeet,
think you were a bit early with the ratings, but I think you'll find you'll have a better result if you do an extended ping and use the source interface of the loopback.
Tony
HI tony
Thanks buddy, I could able to make extended ping from R3 to R6.
Now I could also make normal ping as well. what i did. In BGP table i added directly connected interfaces ip address of (R6, R2, R3). so when i ping from R3 to R6. R6 knows source ip address of packet which is R3 physical interfcae ip address. R6 can find source address in BGP routing table.
Bit still there is RIB failure in my EBGP connection because of static route. do you think this network is successfull in real world. when i remove static route between EBGP routers R2 -- R6 then i lost EBGP connectivity. then EBP goes to active state.
Harjeet,
I think that Cadet Alain, response earlier in the thread spelt it out well, in regards to the RIB errors. It looks like it works to me, in that the loopback associated with the 30.0.0.1 also found it's way into R3 routing table. The only way that was going to happen is if BGP between R2 and R6 was working.
To make it real you might like to put filters on R6 to prevent  the 30.0.0.0 network from being sent to the AS6500 or maybe on the R2 to do the same thing.
Tony.
harjeet,
why would you need to advertise the loopbacks into BGP. You learn them via IGP or static routes to have NLRI reachability. once you are able to ping the loop back interfaces from each neigbor then you establish the BGP peering.
in regards to R3, you can have a BGP peering with R4 and then maybe you can advertise a couple of prefixes into BGP there and you should see them on R4 and R5.just make sure to have the next-hop self configured apprpriately
Kishore
Purple
Hi Kishore,
from the original post it seems all BGP peerings are eBGP so there's no need for next-hop-self.
Regards.
Alain
True dat. just went blind for a while there..not enuff sleep alain
433
