Webcast-Catalyst9k
Basic Frac T1 config
I have a test bed setup with a 7200 and 1841 directly plugged into each other with a rollover t1 card. I'm attempting to make this link a fractioanl T to similuate our remote offices, but every time I try to reduce the timeslots it drops layer2 protocol. Is their a differnet way to reduce bandwith?
controller T1 3/2
framing esf
linecode b8zs
channel-group 2 timeslots 1-7
1 REPLY
Hall of Fame Super Silver
Re: Basic Frac T1 config
Hello Lindsay,
if you want to emulate slower links you can use QoS tool shaping
example
controller t1 3/2
framing esf
linecode b8zs
channel-group 0 timeslots 1-23
policy-map shape-all-500k
class-map default
shape average 500000
int ser3/2:0
service-policy shape-all-500k out
do it on both ends and you can test applications.
One side has to provide clock to the other one in back to back so one controller needs
clock source internal
Hope to help
Giuseppe
155
