Webcast-Catalyst9k
Basic question on AS 5350XM
We have one of them with two Gigabit interface. Is it possible to have insted of them a DSU/CSU as the 3640 has and avoid the use of an external 2620?
Thanks in advance
Juan
1 REPLY
Re: Basic question on AS 5350XM
hi
These are the ports you have or you can have in AS 5350XM on both ingress and egress interfaces..
Egress Interfaces
The Cisco AS5350XM Universal Gateway provides three redundant WAN backhaul methods for moving packets out to the network:
• Two 10/100/10001000BASE-T autosensing Gigabit Ethernet ports
• Two 8-Mbps serial ports
• Any T1 or E1 port on a trunk feature card
Ingress Interfaces
The Cisco AS5350XM Universal Gateway accepts and consolidates all types of traffic, including voice, fax, dial-in analog, digital ISDN, and GSM V.110 calls. It currently supports the following trunk feature cards as ingress interfaces:
• 2-port CT1/CE1/PRI termination
• 4-port CT1/CE1/PRI termination
• 8-port CT1/CE1/PRI termination
• CT3 termination
Additionally, the two serial ports on the motherboard and trunk feature cards can be used for leased-line termination and aggregation using Frame Relay, HDLC, or PPP.
for additional info u can refer this link ..
http://www.cisco.com/en/US/products/hw/univgate/ps501/products_data_sheet0900aecd802f0778.html
regds
268
