Best Practise for OSPF Authentication key(s) at the IntraNet
I wonder if any one knows a link on the best practise for OSPF authentication in the intra-net. We have 10+ ospf areas around the backbone area 0.
I am weighting which way to go, just one key for the entire enterprise or one per ospf area.
Appreciate your input.
Sami
1 REPLY
Silver
Re: Best Practise for OSPF Authentication key(s) at the IntraNet
If really depends on your security policy. What I suggest if it is a closed and controlled network, you can consider one key for the whole network. If you need to peer w/ uncontrolled negibhor, you may consider to use different key for different group of negibhor.
Hope this helps.
98
