Webcast-Catalyst9k
Best router for Bonded T1
Question. I'm installing a Bonded 3meg T1 at one of my remote location. For an edge router what is recommended. 2800 series or 3800? Internally it will connect to a 3560 switch which will then go to a firewall. this router will be strictly used for Routing. Some basica ACL's and that's it.
1 REPLY
Hall of Fame Super Gold
Re: Best router for Bonded T1
Kareem
From what you describe of the requirements the 2800 should be able to handle it. In fact I would think that an 1841 might handle it also.
Rick
178
