Community Member
Best Solution for 120 ports + 2 gbig
Hi all,
I have requirement of 120 ports as well as 2gbig(fiberport),PL suggest the best cisco switch model with low price
1 REPLY
Community Member
Re: Best Solution for 120 ports + 2 gbig
If you won't require Layer-3 capability, I suggest the following:
Two (2) of these:
WS-C2960-48TC-L - 48 10/100 + 2 Dual Purpose Gigabit Ethernet Uplinks
One (1) of this:
WS-C2960-24TC-L - 24 10/100 + 2 Dual Purpose Gigabit Ethernet Uplinks
You also need two (2) SFP modules for the fiber uplink connections. The most common are:
GLC-LH-SM= - 1000BASE-LX/LH SFP transceiver module for MMF and SMF, 1300-nm wavelength
GLC-SX-MM= - 1000BASE-SX SFP transceiver module for MMF, 850-nm wavelength
144
