Webcast-Catalyst9k
best wan failover topology
Hi all
Im looking at designing a wan network, I will have on each site a primary line and a backup line from one provider, then I want to include a third internet connection that backs up them 2 lines but this will be from a different provider.
How would it be best to do this? on the internet router would it be best to use DMVPN, but include it in the same eigrp routing process from my primary provider? what do most people do for this design ?
cheers
Carl
1 REPLY
Super Bronze
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Can't say its best, or speak on what most might do, but I prefer, if possible, to treat VPN site-to-site, from a routing perspective, similar to other WAN routers.  I've done this quite a bit, haven't had any issues, although if WAN routers are using BGP across a L3 VPN cloud, you got to think some about how you're going to route across VPN.
I've used DMVPN, GRE/IPSec and VTI tunnels.
279
