12-27-2009 03:39 PM - edited 03-04-2019 07:04 AM
OLa Partners.
I am having many doubts on how to configure netmasks between two home Router cisco deforms who gains access to a subnet that is connected to the tip of the other home Router. What protocols netmasks should I use to allow this connection? The home Router are already connected via serial as can be seen in the topology sent. I can ping the Gateway 1 Gateway 2.
Hugs
Tiago Eduardo Zacarias
Solved! Go to Solution.
12-27-2009 11:42 PM
Hello Tiago,
unless you are using RIPv1 or IGRP that are classful routing protocols (that means they don't carry the subnet mask in routing updates) you are free to use different subnet masks in the two LAN subnets that can be different also of the subnet mask used on the serial link.
Example:
let's use major network 192.168.16.0.
We can divide this with a /26 subnets creating 4 blocks
192.168.16.0/26
192.168.16.64/26
192.168.16.128/26
192.168.16.192/26
we can further divide first subnet in two /27 subnets
192.168.16.0/27
192.168.16.32/27
we can get a /30 from last block
192.168.16.248/30
Lan segment1:
192.168.16.32/27
serial link: 192.168.16.248/30
Lan segment 2: 192.168.16.128/26
So we are using three different subnet masks for subnets of the same major network Class C 192.168.16.0.
This is called variable length subnet mask.
A dynamic routing protocol can support a scenario like this if in its routing updates it carries the subnet mask of each IP subnet.
let's consider RIPv2
R1:
int eth0/0
desc lan segment 1
ip address 192.168.16.33 255.255.255.224
no shut
int ser0/0
ip address 192.168.16.249 255.255.255.252
router rip
version 2
R2:
int eth0/0
desc lan segment 2
ip address 192.168.16.129 255.255.255.192
no shut
int ser0/0
ip address 192.168.16.250 255.255.255.252
router rip
version 2
Hope to help
Giuseppe
12-29-2009 05:11 AM
In the eigrp 100 config you are announcing the 20.0.0.0 network on both sides.
From the client side you do not have 20.0.0.0, you are using 10.0.0.0 so you will need to announce the 10 network from the client.
So the EIGRP needs to be reversed.
Router 1
eigrp 100
network 20.0.0.0
Client
eigrp 100
network 10.0.0.0
12-27-2009 07:45 PM
Hi Tiago,
Can u brief more, as which protocol you are using and what subnet you have configured for the network connected in the other end, as per my understanding if you were able to ping Gateway 1 and Gateway2 from both the routers, then you need to advertize the subnet under the protocol, just correct me if I'm wrong.
Jana
12-27-2009 11:42 PM
Hello Tiago,
Example:
192.168.16.0/26
192.168.16.64/26
192.168.16.128/26
192.168.16.192/26
192.168.16.0/27
192.168.16.32/27
192.168.16.248/30
Lan segment1:
192.168.16.32/27
R1:
int eth0/0
desc lan segment 1
no shut
int ser0/0
router rip
version 2
R2:
int eth0/0
desc lan segment 2
no shut
int ser0/0
router rip
version 2
Hope to help
Giuseppe
12-28-2009 01:15 PM
Hello Partners.
My solution was to create the dropping routes with EIGRP for their respective segments that wish to access it if i put ping the gateway for any cisco router works beauty but if ping Gateway 1 to Gateway2 or Gateway2 to Gateway1 can not access, so I can ping Interface FastEthernet segment that is in the home Router how to proceed to solve this problem? be problems Jumping netmasks?
12-28-2009 01:51 PM
Can you provide a bit more detail?
For example.
Router 1 config and Router 2 config and what you want to do and what is not working.
Do not share confidential information but in order to help we need to know what you have and what you are trying to do.
12-29-2009 03:35 AM
And the next, I want to accomplish communication with according to the topology of the image sent with the following scenario. Access Gateway 1 Gateway 2 Gateway 2, or access by Gateay 1 .. Have access to 2 segments of the home Router atraz understand? follows below the configuration of home Router.
Router 1
Version 12.4
hostname Central
enable secret 5 $ 1 $ $ merr jLqbUbMQEAg0Ta6dPkp7A0
ip ssh version 1
interface FastEthernet0 / 0
ip address 20.0.0.1 255.0.0.0
duplex auto
speed auto
interface FastEthernet0 / 1
ip address
duplex auto
speed auto
shutdown
interface Serial0/3/0
ip address 200.200.200.1 255,255,255,252
clock rate 125000
interface Serial0/3/1
ip address
shutdown
interface Vlan1
ip address
shutdown
router eigrp 100
network 10.0.0.0
network 200.200.200.0 0.0.0.3
auto-summary
ip classless
line con 0
line vty 0 4
login
end
Router 2
version 12.4
hostname cliente
ip ssh version 1
interface FastEthernet0/0
ip address 10.0.0.1 255.0.0.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Serial0/1/0
ip address 200.200.200.2 255.255.255.252
clock rate 125000
interface Serial0/1/1
no ip address
shutdown
interface Vlan1
no ip address
shutdown
router eigrp 100
network 20.0.0.0 0.0.0.255
auto-summary
ip classless
line con 0
line vty 0 4
login
end
So the scenario would be that the servers are with the gateway set to the ip of the Router FastEthernet interface that will make the netmasks for the other thread.
If aguem can help me I am grateful! Thanks
12-29-2009 05:11 AM
Router 1
eigrp 100
network 20.0.0.0
Client
eigrp 100
network 10.0.0.0
12-29-2009 02:47 PM
Thank you beautiful could help solve this problem. very good this forum thanks for the help even friends!! And a happy new year to all!
Att
