%BGP-3-NOTIFICATION: received from neighbor X.X.X.X 3/5 (invalid length for attribute) 1036 bytes
Hi Sir...
We had some bgp neighbor fail and flapping in a while and we had no idea to fix it till now. Device show us some error message that list below...
Apr 20 14:24:20.238 CST: %BGP-5-ADJCHANGE: neighbor X.X.X.X Up
Apr 20 14:24:21.166 CST: %BGP-3-NOTIFICATION: received from neighbor X.X.X.X  3/5 (invalid length for attribute) 1036 bytes D0100408 000212C9 000003E9 000212C9 00
Apr 20 14:24:21.166 CST: %BGP-5-ADJCHANGE: neighbor X.X.X.X  Down BGP Notification received
Would somebody help us for this case?
Thanks you!
sean
Everyone's tags (1)
Re: %BGP-3-NOTIFICATION: received from neighbor X.X.X.X 3/5 (inv
can you post the output of the below command
#sh run | b r bgp
Karuppu
Hi Karuppu...
Sorry for late response and thanks your help...
this is the summary bgp command that listed below...And the device is 7507MX with IOS 12.0(30)S1 service provider feature.
interface Serial0/1/1
ip address X.X.X.X 255.255.255.252
no ip redirects
no ip directed-broadcast
no ip proxy-arp
load-interval 30
carrier-delay 5
mpls bgp forwarding
tag-switching ip
dsu bandwidth 44210
framing c-bit
cablelength 200
clock source internal
router bgp AAAA
no bgp default ipv4-unicast
no bgp default route-target filter
bgp log-neighbor-changes
neighbor X.X.X.X remote-as BBBB
address-family vpnv4
neighbor X.X.X.X activate
neighbor X.X.X.X send-community extended
neighbor X.X.X.X route-map customer-in in
neighbor X.X.X.X route-map customer-out out
neighbor X.X.X.X maximum-prefix 5000
exit-address-family
route-map customer-out permit 10
match extcommunity 7
set metric 20
route-map customer-in permit 10
ip extcommunity-list 7 permit rt 65001:608094
ip extcommunity-list 7 permit rt 65001:902062
ip extcommunity-list 7 permit rt 65001:905141
ip extcommunity-list 7 permit rt 65001:609251
ip extcommunity-list 7 permit rt 65001:117
ip extcommunity-list 7 permit rt 65001:88888
MP-eBGP receive routes from ASBR device that is filtered by route-map.  And this MP-eBGP had been worked for a long time. But suddenly, the  error message appear  and neighbor flapping continualy. And we cannot  figure it out till now.
Thanks You!
Sean
Hall of Fame Super Silver
Hello Sean,
if you are receiving MP eBGP routes for inter-AS VPNs it is likely that the peer has recently added some BGP communities or BGP extended communities causing an overflow of one field
You should contact them explaining your issue.
Hope to help
Giuseppe
Hi Giuseppe...
The BGP peer is GSR router and we had contacted the GSR owner. The GSR is another servie provider that received route update from downstream customers and they did not changed or tuned any configuration when the problem appear. The GSR receive the same error message from our device and the BGP neighber flapping too. It seems like that GSR is a victim also for this case.
Till now, the error message tell us that the device received update contained malformed BGP communities. And that error makes bgp neighbor flapping. Would some debug or command could tell us that what bgp communities makes bgp neighber flapping?
Thanks you!
Sean
Hello Sean,
if the link is a LAN you could put a sniffer and you could capture the BGP packets sent by GSR to your router and with a common clock you could relate the BGP notification with the offending message.
if the link is of WAN type this is not possible
Hope to help
Giuseppe
Hi Giuseppe...
Yes, this is a T3 wan PA module using coaxial cable and BNC connector and it is difficult to sniffer.
Some debug command had been configured on the device about bgp neighbor update. we terminate the debug asap because of the high CPU consume. And nothing special within the debug logs.
We reviewed the syslogs and found some other new error messages that listed below. Would these messages help this case? and what it mean?
Thanks you!
Sean
Apr 20 14:42:58.779 CST: %BGP-3-NOTIFICATION: sent to neighbor X.X.X.X 3/10 (illegal network) 1 bytes 00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0058 0200 0000 4140 0101 0240 0204 0201 4570 C010 1000 0226 C400 0026 C400 0245 7000 001F 4180 0E20 0001 800C 0000 0000 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D
Apr 20 16:36:15.281 CST: %BGP-3-NOTIFICATION: sent to neighbor X.X.X.X 3/4 (invalid flags for attribute) 16 bytes 0D0B0D0B 0D0B0D0B 0D0B0D0B 0D0B0D0B
Apr 20 16:36:15.281 CST: BGP: 218.96.253.231 Bad attributes FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0079 0200 0000 6240 0101 0240 0204 0201 4570 C010 2000 0226 C400 0026 C400 0245 7000 0000 0100 0245 7000 001F 5F00 0245 700D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B
Apr 20 16:44:53.433 CST: %BGP-3-NOTIFICATION: sent to neighbor X.X.X.X 3/4 (invalid flags for attribute) 14 bytes 0B0D0B0D 0B0D0B0D 0B0D0B0D 0B0D
Apr 20 16:44:53.433 CST: BGP: 218.96.253.231 Bad attributes FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 019C 0200 0001 8540 0101 0240 020E 0206 4570 FEB4 26D3 2570 240D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0B0D 0045 7000 001F 48AC 1300 5074 03B2 C100 0045 7000 001F 48AC 1300 2074 03B6 7100 0045 7000 001F 48AC 1300 1076 03B7 4100 0045 7000 001F 48AC 1300 0476 03BC 9100 0045 7000 001F 48AC 1300 0078 03BE 8100 0045 7000 001F 48AC 100B 6578 03C9 5100 0045 7000 001F 48AC 1005 6578 03CB 4100 0045 7000 001F 48AC 1005 6478 03CD A100 0045 7000 001F 48AC 0701 0170 0957 A100 0045 7000 001F 48DB 579B 7009 6701 0000 4570 0000 1F48 C0A8 6970 0967 5100 0045 7000 001F 48C0 A800 7409 7121 0000 4570 0000 1F48 AC13 0040 6809 7781 0000 4570 0000 1F48 A8A8 7009 7791 0000 4570 0000 1F48 3D1F 3770 0979 9100 0045 7000 001F 480A C8C8 7808 3561 0000 4570 0000 1F48 AC10 1E65 7808 3851 0000 4570 0000 1F48 AC10 0065
Hello Sean,
what IOS image is running  on your router and what device is the BGP peer?
the message clearly states that a BGP advertisement from the peer was containing a BGP attribute in the form of type length value and that the value field 1036 -> 1036 octets  was not a valid expected value.
Be careful that the BGP peer may be misbehaving or it is trying to send to you a too long AS path attribute (for example)
means sent notification for having received a malformed BGP update (3) with a BGP attribute lenght out of range (5)
the router is protecting itself from possible SW errors that would be caused by accepting the update
Are you protecting your router from too long AS paths with max-as command ?
Hope to help
Giuseppe
Hi Giuseppe...
The device is 7507MX with IOS version 12.0(30)S1 service provider feature. Definitely, there is a BGP Bugs about too long AS-Path. I am not sure that the device and IOS had fixed this or not. But the config had worked for a long time but this error message is the first time that appear. And we had no idea to fix this...Maybe something wrong about route update. Would some command or debug could help us to figure it out?
Thanks You!
Sean
Dear  CHENG-HSIN LIN :
I encountered the same problem like yours.
My device is 7513 with IOS version 12.0(30)S1.
You mention there is a BGP Bugs about too long AS-Path.
I have looked for the Bug with Cisco BUG Toolkit , but I can't find.
Could you tell me where you find it??
Hello Tyllin,
all started with an event happened in the internet in Feb 2009
see this article from Ivan Pepelnjak
http://blog.ioshints.info/2009/02/oversized-as-paths-cisco-ios-bug.html
the issue has been discussed also here in the forums
Hope to help
Giuseppe
Dear  Larosa :
Thanks for your help . I have read the article.
But it seems nothing to my problem. Because I don't config "as-prepend" & "bgp maxas-limit"
when the upstream router config below
neighbor 61.31.244.194 send-community both
neighbor 61.31.244.194 route-map cust-community in
the error message show :
%BGP-5-ADJCHANGE: neighbor x.x.x.x vpn vrf c109a071 Down BGP Notification received
%BGP-5-ADJCHANGE: neighbor x.x.x.x vpn vrf c109a071 Up
%BGP-3-NOTIFICATION: received from neighbor x.x.x.x 3/5 (invalid length for attribute) 1444 bytes D01005A0 00
02121D 00000821 000212C9 00
when I remove the config : It's ok.
Upstream Router (7513 + 12.0(30)S1):
ip vrf c109a071
rd 9924:1041
route-target export 9924:1041
route-target import 9924:1041
router bgp 9924
ip vrf forwarding c109a071
address-family ipv4 vrf c109a071
redistribute connected
redistribute static
neighbor x.x.x.x remote-as 65001
neighbor x.x.x.x activate
neighbor x.x.x.x as-override
neighbor x.x.x.x soft-reconfiguration inbound
neighbor x.x.x.x maximum-prefix 500 80 restart 10
ip community-list standard pref150 permit 650379414
ip community-list standard pref200 permit 650379464
route-map cust-community permit 10
match community pref200
set local-preference 200
route-map cust-community permit 20
match community pref150
set local-preference 150
route-map cust-community permit 1000
Downstream Router (65093 + 12.2(17d)SXB1):
router bgp 65001
no synchronization
redistribute static
neighbor x.x.x.x remote-as 9924
neighbor x.x.x.x route-map Primary_BGP_out out
default-information originate
no auto-summary
access-list 91 remark Control BGP out
access-list 91 permit any
route-map Primary_BGP_out permit 10
match ip address 91
set community 200
so it seems the extended communities sent from the upstream router might be breaking the BGP session?
What about trying
neighbor 61.31.244.194 send-community standard
instead of
neighbor 61.31.244.194 send-community both?
I'm also not sure if the downstream router config works OK
without
neighbor x.x.x.x send-community standard
But it's difficult to advise without knowing the detailed purpose of sending communities between your routers.
BR,
Milan
Purple
Hi Milan,
Isn't he doing so to propagate its route-targets which are extended communities  ?
Regards.
Alain.
I'm not sure.
I always thought this was done for vpnv4 neighbors, but not for ipv4  neighbors?
BR,
Milan
Hello Alain,
from what we have seen up to now this should be an eBGP session between a PE and a CE so extended communities shouldn't be of use as noted by Milan
Hope to help
Giuseppe
Hello Tyllin,
What is the router that complains of 3/5 (invalid length for attribute)  the PE node or the CE node?
as noted by Milan you should use
send-community on both sides and not send-community both only on PE side
Hope to help
Giuseppe
Purple
Hi Milan,Giuseppe,
Thanks for clarifications about the extended communities
Regards.
alain.
Dear  Eveybody :
Thanks for help again^^
The below config  & eroor log is on Upstream Router (7513)
I'll try to set up send-community both side
Hi, I am having a problem of communication between two ASR9000 router (ver 4.2.1)  and a 7604 router (
RSP720 ios 122-33.SRE2 ),  I am configuring the  ASR as VPNv4 RR,  but the peer with the 7600 never establishing
the config. the equipment is as follows
ASR:
router bgp 22222
address-family ipv4 unicast
address-family vpnv4 unicast
address-family l2vpn vpls-vpws
neighbor X.X.X.X
  remote-as 22222
  update-source Loopback0
   next-hop-self
   route-reflector-client
7600
router bgp 2222
neighbor y.y.y.y remote-as 22222
neighbor y.y.y.y update-source Loopback4090
address-family ipv4
no synchronization
bgp redistribute-internal
  no neighbor y.y.y.y activate
  neighbor y.y.y.y send-community both
address-family ipv4 vrf PEPE
  no synchronization
  redistribute static
neighbor PEPE peer-group
neighbor  PEPE remote-as 22222
neighbor PEPE route-reflector-client
neighbor PEPE soft-reconfiguration inbound
neighbor 192.168.95.9 peer-group PEPE
neighbor 192.168.95.9 activate
and more vrf with similar configurations  .................
log error in ASR
RP/0/RSP0/CPU0:Feb  2 16:24:45.198 : bgp[1044]: %ROUTING-BGP-5-ADJCHANGE : neighbor x.x.x.x Up (VRF:default)
RP/0/RSP0/CPU0:Feb  2 16:24:45.236 : bgp[1044]: %ROUTING-BGP-5-ADJCHANGE : neighbor x.x.x.x Down - BGP Notification sent, illegal network (VRF: default)
RP/0/RSP0/CPU0:Feb  2 16:24:54.418 : bgp[1044]: %ROUTING-BGP-5-ADJCHANGE : neighbor x.x.x.x Up (VRF: default)
RP/0/RSP0/CPU0:Feb  2 16:24:54.452 : bgp[1044]: %ROUTING-BGP-3-MALFORM_UPDATE : Malformed UPDATE message received from neighbor x.x.x.x - message length 101 bytes, error flags 0x00000008, action taken "Reset". Error details: "Error 0x00000008, Field "MP_REACH-NLRI", Attribute 14 (Flags 0x00, Length 0), Data [53]"
log 7604
Feb  2 16:24:13.839: %BGP-5-ADJCHANGE: neighbor y.y.y.y Up
Feb  2 16:24:13.839: %BGP-3-NOTIFICATION: received from neighbor y.y.y.y 3/10 (illegal network) 1 bytes 53
Feb  2 16:24:13.839: %BGP-5-ADJCHANGE: neighbor y.y.y.y Down Peer closed the session
Feb  2 16:24:13.839: %BGP_SESSION-5-ADJCHANGE: neighbor y.y.y.y VPNv4 Unicast topology base removed from session  Peer closed the session
I would appreciate any help from already thank you very much for your time
Sergio
8296
