bgp active path
Setup is as below:
2 routers at branch site connected to headend, with headend also having a pair of routers. These are running bgp.
At any time, only one of these would be active on bgp. How is it possible to find which router is running active bgp session.
any commands or outputs to identify?
Thanks in Advance.
1 REPLY
VIP Super Bronze
Re: bgp active path
You can use "sh ip bgp" it will show you the active and best route to a prefix.
Example:
Router# show ip bgp
BGP table version is 5, local router ID is 10.0.33.34
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*> 10.1.0.0          0.0.0.0                  0         32768 ?
*  10.2.0.0          10.0.33.35              10             0 35 ?
*>                   0.0.0.0                  0         32768 ?
*  10.0.0.0         10.0.33.35               10             0 35 ?
*> 192.168.0.0/16   10.0.33.35               10             0 35 ?
the route with *> in front of it is the best active route.
http://www.cisco.com/en/US/docs/ios/12_3/iproute/command/reference/ip2_s2g.html#wp1039007
Reza
138
