Community Member
BGP advertise issue
we established private bgp with a customer, and they advertise several routes to us from two sites.
10.1.1.0/24
10.1.2.0/24
10.2.1.0/24
and only one of the route 10.1.1.0/24 set with tag, is that possible I could force all traffic (including 10.1.1.0/24, 10.1.2.0/24 and 10.2.1.0/24) sent back to where their bgp set tag?
thx
Re: BGP advertise issue
i dont whether i understood your question properly..
If you want to set the tag for all the incoming routes you can use a route-map for the routes received from the BGP peer
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 1 permit 10.1.2.0 0.0.0.255
access-list 1 permit 10.2.1.0 0.0.0.255
route-map SetTag permit 10
match ip address 1
set tag
router bgp 100
neighbor 1.1.1.1 remote-as 200
neighbor 1.1.1.1 route-map SetTag in
HTH, rate if it does
Narayan
Community Member
Hi, Narayan:
Thanks for your quick reply, the problem is we have two sites, and we have a bgp peer with customer at each site. and they could set the tag dynamically just for 10.1.1.10/24 from site a or site b. and I need to force the traffic back where the site tag has been set.
thx
Narayan,
You can't use tags with BGP. In most IOS releases, you would get the following message if you try to configure a route-map that sets the tag for a BGP session:
RouterA(config-router)#nei 192.168.12.2 route-map test in
% "test" used as BGP inbound route-map, set tag not supported
RouterA(config-router)#nei 192.168.12.2 route-map test out
% "test" used as BGP outbound route-map, set tag not supported
RouterA(config-router)#do sh route-ma test
route-map test, permit, sequence 10
Match clauses:
Set clauses:
tag 999
Policy routing matches: 0 packets, 0 bytes
You would rather use the community attribute instead.
Hope this helps,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Community Member
sorry, my mistake, I meant 10.1.1.0/24 has been set with community, but I want all the traffic sent back to them where the peer which set the community.
thx
From what I understand of your setup, you could just set a higher local preference when based on the received community.
Also, to ensure attached community attributes are sent peer, make sure the peer is configured with the "neighbor send-community" command.
Hope this helps,
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Community Member
Hi, Hritter:
that only resolve 10.1.1.0/24 issue, but it does not resolve 10.2.1.0/24 issue, which they did not attatch any community.
OK, you have to tell us a bit more about the problem you are trying to solve.
Do you receive all three mentioned prefixes from both peers?
Do you run iBGP between your two routers?
Do you redistributed in the IGP?
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Community Member
yes
yes
no
thx
Could you please then explain what you are trying to achieve.
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Community Member
Hi, Hritter:
10.1.1.0/24
10.1.2.0/24
10.2.1.0/24
customer from site A sends 10.1.1.0/24 with community 65501:10, but no community with route 10.1.2.0/24 and 10.2.1.0/24
also they have site B send all those routes as well with no community attached.
but customer could send 10.1.1.0/24 with community from site A or site B dymanically.
No from Both sites.
our site C is connected with customer site A
site D is connected with customer site B
when I see 10.1.1.0/24 with community attached, I want to force the traffic back on all customer routes where they sent.
thx
The best thing would be to ask your customer to set the community attribute for all prefixes on the site where they want traffic to come back.
Hope this helps,
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
2566
