BGP advertising
I'm recieving a full bgp table from a neighbor which is hosted at an upstream provider on my 7200 router. I have another router 7500 which shares the same bgp as as the 7200. However I would not like the recieved routes from this neighbor to be transfered to the 7500 router. Am I correct when saying i need a route-map?
1 ACCEPTED SOLUTION
Re: BGP advertising
Hi Keith
you can do that..
Alternatively you can also deny the route-map and use permit access-list
HTH, rate if it does
Narayan
Re: BGP advertising
Hi friend,
There are lot of ways to achieve this but route map is the preferred option as it offers a lot of features.
All you have to do is to configure a route map with an access-list permitting the networks you want to advertise.
access-list 1 permit y.y.y.y
route-map adv-to-7500 permit 10
match ip address 1
router bgp 100
neighbor x.x.x.x route-map adv-to-7500 out
Narayan
Re: BGP advertising
I do not want any of this bgp table to be advertised onto other routers. this 7200 is my default gateway for my internal network.
In your sample config would this acl accomplish this?
access-list 1 deny any any
Keith
Re: BGP advertising
Hi Keith
you can do that..
Narayan
Re: BGP advertising
Hi Keith,
I would use as-path filters in this scenario as there are more flexable. The below config achieves this. The deny statement in the AS path filter shoule be set to the AS number of the peer you want to block (I've used 65001 as an example). This setup will allow other BGP routes to be sent from the 7200 to the 7500 if this is a requirement.
router bgp 65000
no synchronization
bgp log-neighbor-changes
neighbor <7500 address> remote-as 65000
neighbor <7500 address> filter-list 1 out
ip as-path access-list 1 deny permit ^65001_([0-9]*)$
ip as-path access-list 1 permit .*
176
