BGP and EIGRP help
Rupesh Kashyap
Hi, I have router A and B running BGP (5.0.0.0). I have created GRE Tunnel between them working on EIGRP(10.3.1.0).
I have published 10.50.0.0 both in BGP and EIGRP on router A. Now I am seeing EIGRP Tunnel as primary
on Router B. Ideally it should primary as BGP AD-20. Please help.
B>
* 10.50.0.0/16 5.0.0.1 0 65000 65040 i
*> 10.3.1.13 1561600 32768 ?
B>sh ip b 10.50.0.0
BGP routing table entry for 10.50.0.0/16, version 2104
Paths: (2 available, best #2, table Default-IP-Routing-Table)
Not advertised to any peer
65000 65040, (aggregated by 65040 6.0.0.1), (received & used)
5.0.0.1 from 5.0.0.1
Origin IGP, localpref 100, valid, external, atomic-aggregate
Local
10.3.1.13 from 0.0.0.0
Origin incomplete, metric 1561600, localpref 100, weight 32768, valid, sou
rced, best
Not applicable
Harold Ritter
Rupesh,
The issue is that you are redistributing EIGRP into BGP on router B. This causes 10.50.0.0/16 to be seen as locally originated on router B (from 0.0.0.0) and to have a weight of 32768, which is preferred over the path received from router A via BGP.
Make sure you do not redistribute EIGRP routes received from router A back to router A via BGP and vice versa.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
yes sir. I got the same detail on Cisco site. Thanks for this big help.
