11-17-2010 07:58 PM - edited 03-04-2019 10:29 AM
Dear All,
I have an odd case please see the diagram link below, i need reach from R-C01 (192.168.253.0/24) to 192.168.90.0/24 load balance or load sharing via R-BH-01 and RR01 is it posible ? how to configure it?
Solved! Go to Solution.
11-17-2010 11:28 PM
From your exhibit, I assume that R-C01 knows about the network 192.168.90.0/24 via OSPF only, and that the route is learned as external (redistributed). You have not indicated whether the route is advertised as External Type-1 or External Type-2.
In general, the OSPF can perform only equal-cost load balancing. That implicates that the R-C01 must consider both routes to the network 192.168.90.0/24 of equal cost, only then it will perform load balancing. In turn, that means:
Obviously, you would need to manually modify the link costs to get the desired effect.
As a general rule, a routing protocol is responsible for populating the routing table with accurate and complete information about best paths to any reachable destination. However, what you want to do is basically traffic engineering, and that is out of scope of routing protocol competences. We can force a routing protocol to perform load balancing for a certain set of destinations but for more general deployments, we have to resort to specific traffic engineering mechanisms such as MPLS-TE.
Best regards,
Peter
11-17-2010 11:28 PM
Best regards,
Peter
11-18-2010 12:32 AM
Hi Peter,
Many thanks for your reponse, yes it works i did manipulate the ospf cost and med for BGP, i'm just afraid after i implement in production it could caused asymetric routing or somthing.
R-BH-01
Router ospf 600
redistribute bgp 600 metric 299 metric-type 1 subnets
router bgp 600
redistribute ospf 600 metric 100 match internal external 1 external 2
R-BH-02
router ospf 600
redistribute bgp 600 metric 97 metric-type 1 subnets
router bgp 600
neighbor loadsharing route-map med_600 out
access-list 66 permit 192.168.253.0 0.0.0.255
route-map med_600 permit 10
match ip address 66
set metric 90
route-map med_600 permit 100
set metric 200
