BGP and OSPF Stable
How can I verify if OSPF is stable between sites? What are parametrs that I can verify?
How can I verify if BGP is stable between sites? What are parametrs that I can verify?
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: BGP and OSPF Stable
marcelo.fanaia wrote:
This time is too much for last time the route was updated. Isn't It? What do you think about?
B     192.168.111.0/24 [20/0] via 10.1.0.2, 06:01:25
B     128.254.216.0/22 [20/0] via 10.1.0.2, 06:01:37
Best Regards
Marcelo
Marcelo
BGP does not send periodic routing updates as other protocols do. So unless the route has changed no update will be sent.
Jon
VIP Super Bronze
For OSPF, if you issue "show ip ospf neighbor detail" it will show you how long the neighbor has been up
For BGP issue "sh ip bgp su" this will also tell you how long the neighbor has been up and running
Reza
Best Regards
Marcelo
Best Regards
Marcelo
Marcelo
Jon
You are right! Thanks for your answer.
Best Regards
Marcelo
239
